Flags: N, V, Z, C - what are they worth to you?
Re: Flags: N, V, Z, C - what are they worth to you?
Well, if you have carry, you can test for zero by adding FF and then testing the carry - so zero is optional. But I agree, it's very useful!
In a recent but very recently superseded effort at a minimal CPU, we had predicates for carry and non-zero. (We thought that branching on non-zero is just a little more valuable than branching on zero.)
Interestingly, in an accumulator machine you could have a test for zero which tests the accumulator directly, and yet omit the zero flag. So that's an intermediate situation - you have a test, but no flag bit. Once you start adding other registers, like the 6502's X and Y, then a zero flag looks more useful - only being able to test the accumulator is limiting.
- GARTHWILSON
- Forum Moderator
furrykef wrote:
The V flag is often considered the 6502's least useful flag. Even large programs may never use it at all.
- BigDumbDinosaur
The processor flags as a whole are completely unnecessary if a CPU instruction set is designed that way. Instead of having instructions like "branch if ... flag is set/clear", we have "branch if RegX > RegY" or "brankch if RegX is zero/nonzero". We could even do it 65xx style and have "branch if A is higher than MEM" or stuff like that. It's just as intuitive, and removes the need for flags. The major inconvenient is that it needs a wider set of instructions to reach the same functionality, and is harder to delay decisions (rather than just store the decision in the flag and use later, we have to keep the comparison source in registers).
Mulling over alternative CPU designs, it feels like the four flags are not equal in usefulness. The following is a thought experiment.
If you could have a CPU that's 10% faster, 10% cheaper, would you give up one of the four flags? Which one?
I don't think I'd want to lose any of the other flags as it would make all reference code incompatible, and make writing code more painful. That said, if I _had_ to choose:
- 3 flags: N, Z, C
- 2 flags: Z, C
- 1 flag: C
This is what I'd like to do, but I can't because no Z:
LDA this_variable
CMP that_variable
BEQ this_that_equal
; not equal
this_that_equal:
; equal
.MACRO CMPZ OP
PHA
LDA \OP
JSR fcmpz
PLA
.ENDMACRO
; client application
LDA this_variable
CMPZ that_variable
BCS this_that_equal
; not equal
this_that_equal:
; equal
fcmpz:
PHA
TXA
PHA
TSX ; X->[-, X, that_variable, ret_lo, ret_hi, this_variable]
LDA $102,X
EOR $105,X
AND #$0F
LSL
STA cmpzcall1 + 1
cmpzcall1:
JSR cmpztab
BCS cmpzend
LDA $102,X
EOR $105,X
AND #$F0
LSR
LSR
LSR
STA cmpzcall2 + 1
cmpzcall2:
JSR cmpztab
cmpzend:
PLA
TAX
PLA
RTS
.ALIGN 256
cmpztab:
SEC
RTS
.REPEAT 15
CLC
RTS
.ENDREPEAT
sark02 wrote:
Ugh, that looks awful.
LDA this_variable
EOR that_variable
CLC
ADC #$FF
BCC this_equals_that
; this_not_equal_to_that
"Hello, my name is dummy. Nice to meet you." - me.
White Flame
If you don't have a Z flag, you can always create a "Branch if A is zero" instruction instead, which uses the entire register as a simulated flag. Forth does this with TOS a lot for decisions, for example. Without a C flag, you could also overwrite X or Y with carry. This obviously tramples a lot of state, but might reuse a lot of data paths in the CPU instead of routing to specialized flag registers.
Not all processors even have a V flag.
Add minus 1 and a C test for to replace Z. ( 2's complement )
N can be tested with an add to one self and a C test.
That leaves only C for every thing.
Dwight
Dwight
- BitWise
- In Memoriam
MIPS processors (as in the PIC32) have no flags at all. There are a few conditional instructions (e.g. branch if reg1 == reg2, compare and set register, etc.) and a register that always contains zero and which can be compared against.
The compiler derives carry from intermediate results, for example 64-bit add on a 32-bit device.
The first ADDU add the low words, the second the high words. The SLTU sets V1 to one if a carry occurred otherwise zero. The final ADDU (in the delay slot after the jump to return address) propagates it into the result.
One of the add instructions can trigger an overflow interrupt but many languages like C don't use it.
11: long long add (long long a, long long b)
12: {
13: return (a + b);
9D000234 00C41021 ADDU V0, A2, A0
9D000238 00E52821 ADDU A1, A3, A1
9D00023C 0046182B SLTU V1, V0, A2
14: }
9D000240 03E00008 JR RA
9D000244 00651821 ADDU V1, V1, A1
Andrew Jacobs
Back in the 20th century I worked with minimalist CPU's that did multi-axis motion control, and the technology was 7400 series TTL (no microprocessor). Program memory was a pair of bipolar PROM's, and each 16-bit instruction included only three opcode bits.
There were a few wrinkles that allowed eleven possible instructions, not just eight, but it was definitely minimal.
The machine had just a single status flag, and its meaning depended on the context (Dwight and Sark02 mentioned points along this line). The flag got its data from two possible sources. An ADD instruction would write its Carry result to the flag, whereas a BIT instruction caused the flag to update reflecting the Zero result.
There was only one instruction to test the flag -- a conditional branch. I don't recall whether it branched on flag set or on flag clear.
Hi Dr.
As often with me, I missed that there was a page 2.
I get to excited to post and don't look.
Even Z can do all but a little different. I suspect
that one could even use N or V as well with a little
thought.
Dwight
thought.
Dwight
- BigDumbDinosaur
Very interesting thoughts and observations, everyone! I hadn't realised PIC32/MIPS was flag-free. I know RISC-V is.
For the OPC series of CPUs, it looks like we're going with Z and C at present, and just C for the minimal machine.
- Alarm Siren
I've got a homebrew architecture which has four flags:
C - Carry
V - Overflow
I - Interrupt Enable
U - User
C & V are provided by the ALU chip I'm using. I is obvious what it does. U is never set or cleared by the hardware at all, but the programmer can do so, and it has its own set of branch instructions. I originally intended to have U be a Z flag, but the way i've implemented the flags register unfortunately makes this impossible.
At least, I recall there being a reason but I cannot remember what it is now....
I did consider not using V and providing C and Z instead, but it does seem to me that V is particularly hard to simulate if you are using signed arithmetic and don't have the flag. Whereas Z is relatively easy to simulate.
EDIT: had a look at my circuit diagrams - its because it can't modify the U/Z flag without also clearing the I flag, which is not a good idea....
C - Carry
V - Overflow
U - User
Interesting! Have you written anything about your architecture?
