litwr wrote:
This idea of fully relocatable code is a chimeric descendant of PDP/VAX-11 ISA. But even PDP/VAX-11 couldn't get it. Nobody needs this. It is impossible to use program without a proper loader in the complex OS. IMHO PER is just a waste of the codespace. Did anybody use it?
EDIT. It is also worth to note that there is a true OS for 6809/6309 - FLEX. 6502 family missed this. 6502 has only Basics and Forth.
FLEX was no more exciting than CP/M in the OS space -- i.e. it was a shell that could load programs and offered a BIOS/BDOS. SpartaDOS was no slouch on the Atari 8-Bit.
OS/9 was a multi-tasking OS for the '09, and, early on, all of its processes were written using position independent code, no launch time loader was necessary.
Early MacOS did this also, relying on PIC routines. This was fully exploited by the MultiFinder. There was system support (notably for calling different segments of code within the application), but no real loader per se. Of course, UCSD P-Machine did this also, at the p-code level. All of their code was PIC with the segments tied dynamically loaded at runtime. Both the Mac and UCSD required compiler support for multi-segment calls.
You could do the same thing on the '816 (IIGS did this a little bit, with desk accessories), with the caveat that your individual processes could only have < 64K of code, but they could access more than that for data. The OS would need to have a way to portion out Bank 0 as a shared stack space among the processes, but (almost) 64K of Bank 0 should handle hundreds of processes. Each processes meta data can specify a stack size.
None of this requires a loader, but it does need a decent memory manager. And, yes, there's no protection among the processes -- that's a different issue.
