sepseel wrote:
So normally my clock runs at 1 MHz, and I have a 1,8432 MHz crystal for the acia.
I suspect however that the acia crystal is not operating as it should, this may also be the cause for my problems I think.
Given the ubiquity and low cost of present-day can oscillators, you may ultimately
prefer to use one for your X1 clock instead of the crystal and associated components. Can oscillators are very trustworthy, produce plenty of drive, and take up little space. Also, all the issues associated with getting a crystal to resonate in the right way under all reasonable operating conditions have been worked out for you. The last time I used a crystal with a UART was in 1989, when I hacked together my version of CMD's SwiftLink for one of my Commodore 128D machines, using a 6551. Around that time, can oscillators started to come down in price and power consumption, and I never looked back. My POC units have two such devices, one for generating the Ø2 clock and the other for generating the UART clock (3.6864 MHz with NXP UARTs). Plug 'em in and they work!
As for the single-stepping method, I just step the clock. Would using RDY be better or easier ?
I'm not an expert on the 6551 hardware, but if the one you are using is an NMOS part I suspect it doesn't react well to have Ø2 stopped. The 65C02, on the other hand, can tolerate having Ø2 stopped when high, and the WDC 65C02 is fine with stopping Ø2 on either phase. Garth or a few others (Dr. Jefyll?) might be able to opine on this.
