cbmeeks wrote:
I've owned a Commodore PET 8032 for many years...I'm thinking about using tinkering with it this weekend...So, other than that giant capacitor and the AC transformer, what else do I need to be careful of before (and after) I power this thing on?
Electrolytic capacitors are your main concern in old electronic devices. Most everyone knows that old electrolytics can dry out after a number of years of no use and then fail upon being powered. Fortunately, capacitors usually can be replaced without a lot of difficulty.
I wouldn't worry too much about the power transformer. Those things can last for many decades and usually aren't affected by long periods of non-use. On the other hand, the flyback transformer, which is part of the circuitry that develops the high voltage needed by the CRT's ultor (accelerating or "secondary" anode), could go south at any time. Back in the days when I used to fix TV sets to produce some extra income, I'd say that flyback failures represented about 20 percent of all failures I encountered. I'm not trying to scare you, just alert you to a possible problem that could arise.
If you want to be extra cautious before you power the unit, disconnect the ultor lead from the CRT and carefully clean the CRT's surface around the ultor connection. The best way to do this is to spray some glass cleaner on a lintless cloth and then wipe the glass around the ultor connection. Do not spray glass cleaner on the CRT itself. After cleaning around the ultor connection, use a can of "air" to blast the ultor socket and clear it of foreign matter. Before reconnecting the ultor lead, clean its rubber boot with glass cleaner and your lintless cloth. Following this procedure will eliminate the likelihood of arcing around the ultor connection, which could take out the flyback transformer if it does occur.
