Seem I started a bit of an argument here, though I'm certainly learning a lot about MOSFETs watching! I decided to proceed with the MOSFET protection circuit as-is, as Garth appears to be in the minority in this case. If it doesn't work, I can just remove the mosfet and bridge the connection with a nice blob of solder.
Anyway, I've been busy beavering away on this project, and I present to you the completed layout. Took all weekend, entirely by hand.
All the images are SVG this time, so you can (at least in theory) infinitely zoom with no loss of quality. I have also uploaded both colour and greyscale versions.
I was unable to upload directly to the board as SVG images are apparently not permitted. I've dumped them on my dumping-domain instead.
Revision 7 Schematic, ColourRevision 7 Schematic, GreyscaleRevision 7A PCB Layout, ColourRevision 7A PCB Layout, GreyscaleNote that the PCB is a four layer boad, and the upload does not show the two internal layers. There's really nothing special on them, just a giant power and ground copper pours.
Want to design a PCB for your project? I strongly recommend
KiCad. Its free, its multiplatform, and its easy to learn!
Also, I maintain KiCad libraries of
Retro Computing and
Arduino components you might find useful.
