[22k pulldown resistors > data bus]
I put them in so if I attempt to access a non-existent device (ROM Cart not plugged in, non-implemented I/O
device, etc) I'll get a known value (0). I wasn't sure, and could find no information on, whether the Data bus
pins on the 65c02 has internal pull resistors for this purpose or no.
I don't think that the 65C02 data bus pins have internal pull resistors.
Having a known value on the data bus in case of having an "open" data bus makes sense.
[16kB RAM]
Fair point and not one I'd given much thought to, but equally I'm not expecting this design to directly
drive graphics. If it outputs to a monitor at all, it'll be via the RS-232 or one of Daryl Richtor's
Text Video boards. I shall bear this in mind for the future, non-uni-project version though.
So it's only text mode (for debugging), and this text mode doesn't have to be fast.
BTW: there might be text LCDs with SPI.
Trying to avoid flash-proper because of the page-write thing. Not an issue for the BIOS chip,
I suppose, but I'm using the same chips in the Program Cartridge, and I'd like for it to be possible
(at least in principle) for the SBC to write to its own ROM, with a minimum of complexity.
I've not put up the schematics for that, but the four chips on the Cart have jumpers to
allow/deny writing to them individually.
Write protect, nice idea.
It is true that the page layout of flash memory chips might vary a little bit...
For now, One-Time-Programmable is definitely off the table, even for the BIOS: this thing is going to be
buggy as hell initially. My programs always are
. I shall bear in mind this way of doing things
(that is, bootloader on board, big ram, main ROM on SPI) for the future though.
It definitely sounds like it has merits to me.
Well, if OTP ROM _only_ would contain a boot loader, one could focus on making a bug free boot loader,
and the rest of the software which would be going to be loaded into RAM could stay as buggy as hell.
[16C550]
Can you be more specific? The pin descriptions and timing diagram suggest to me it should be fully compatible...
Hmm... I now have to admit that I haven't used the 16C550 together with a 6502.
But I remember to have had some timing problems back in 2000, when using a chip similar to the 16C550
together with a Shark (ADSP21065L). So I made this remark just out of a "gut feeling".
Anyhow, using non_6502 related peripheral chips on a 6502 bus could provide more trouble
than using 6502 related peripherals on a 6502 bus...
Fair points; means I have to edit both the schematic symbol and the footprint of the DE9.
What fun. Wouldn't the resistors interfere with the voltages though? The transceiver is already
(from my understanding) only capable of driving up to +/-5.5V, which is pretty close to the RS-232
no-go-zone.
I'm not familiar with the MAX level converter you are going to use,
but I had used 100 Ohm resistors together with a MAX3232.
Depends on the current that is going to flow through the resistors,
if you are paranoid just change 100Ohm to 22Ohm.
The 16C550 and the 6522 have more than one chip select input,
maybe you could throw out one of the 74138s in the address decoder
when making "creative use" of the unused chip select inputs.
I did exactly that in an earlier revision, my supervisor suggested I not do it that way.
Sorry to hear, that it's a political thing. !
There are three sensitivities available: 5%, 10% and 15%. I have ordered the 5% one.
I get what the extra cap would do, but what would the resistor achieve?
The resistor and the extra cap would build up a low_pass filter for the 3.3V supply of the DS1818.
I had used TL7705 for generating /RES, and that chip has quite a reputation to being a bit
sensitive to "dirt" in the power supply.
In most circumstances (and certainly once I've finished developing everything),
the SBC will be powered from the FPGA board via the VHDC connector.
The screw terminal is so I can power it from a bench power supply during development,
when I've put in the "real" 65c02 instead of the FPGA. As such, I don't envisage it
being a particular issue. Nevertheless, it can't hurt to throw in a clamping diode.
Ja, so when some of the mechatronics students had toyed with their little robot
here at the university, they accidentally had reversed the power supply
shortly before the project deadline... what meant replacing plenty of chips...
[74393 clock generator]
Fair enough. I'll look at that for the non-project versions, but for now the 4MHz Oscillator etc
have already arrived.
Yep, you got to go with what's there, then with what's available.
Good knowledge, though I'm not intending to have this SBC directly drive a monitor.
If it does so, it'll be via the RS-232 or one of Daryl Richtor's Text Video peripheral boards.
That's OK, just be sure that the computer still works when no video display is installed...
Good luck with your project, looking forward to watching your progress.
Thank you, and I am extremely grateful for your input.
You are welcome, and we always like to see a new 6502 project here in the forum.
