It is currently Fri Nov 22, 2024 4:13 am
 Post subject: uxForth for the VIC-20
PostPosted: Tue Nov 08, 2016 2:51 pm
Julian Skidmore aka Snial is writing about writing a Forth for the VIC-20 - a classic small-RAM 6502 keyboard-sized computer.
Part 1, the appeal of the VIC-20.
Part 2, the different types of Forth interpreter.
(For me, these diagrams are much more digestible than a textual description.)
PostPosted: Tue Dec 06, 2016 7:02 pm
Consider a hybrid of the two. A secondary would be a list of one-byte or two-byte tokens
  • One byte (with the sign bit set) treated as an index into a 128-element table of addresses of most common words
  • Two bytes, (with the sign bit clear), to be treated as the high address byte
    The second byte is the lower address byte
The inner interpreter NEXT routine might look something like:
; somewhere on the zero page, allocate 3 bytes
iplo
   .byte 0
ippage
   .word $0400
; this code goes elsewhere
next
   inc iplo            ; bump the instruction pointer
   bne noflip
   inc ippage            ; flip to the next code page
noflip
   ldy iplo
   lda (ippage),y         ; fetch the instruction
   bpl twobytes         ; positive?  this is addr high byte
onebyte
   tay                  ; negative? this instruction is an index
   lda wordshi-$80,y      ; subtract 128 to take the sign bit into account
   pha
   lda wordslo-$80,y
   bne out               ; bra
twobytes
   pha
   iny
   sty iplo            ; finish up the two-byte addresses
   lda (ippage),y
out
   pha
   rts
PostPosted: Wed Dec 07, 2016 1:11 am
The diagrams *are* well done. They're found at the second of the two links Ed posted.
chitselb wrote:
Consider a hybrid of the two. [...] The inner interpreter NEXT routine might look something like:
Something like, yes. :P
But I think...
... should be...
   inc ippage+1            ; flip to the next code page
Also, when a two-byte token is fetched there's another increment of the pointer at ippage -- but it's just an 8-bit increment. It's lacking a test for roll-over into the high byte.
PostPosted: Wed Dec 07, 2016 1:32 am
wups, yes ippage+1. contents of ippage is always a 0, and the pointer within that page is in Y
But I think...
... should be...
True. In PETTIL (a direct-threaded Forth) I'm used to having the compiler insert the word PAGE (to increment IP+1) within a secondary when it crosses a page boundary. That might be possible here too.
PostPosted: Wed Dec 07, 2016 1:40 am
I wondered about that. It's an idea worth remembering.
Yup. And it could be applied in all cases -- ie, regardless of whether the page crossing results from the fetch of an 8-bit or of a 16-bit token.
PostPosted: Wed Dec 07, 2016 4:20 pm
The intended tradeoff here is lose clocks to gain bytes, so we can squeeze more code into a stock 5K VIC-20, so a one-byte PAGE token is the way to go. But include the ability to have more than 128 words in the dictionary. I can imagine using this approach in some type of target-compiled project. It should also be noted that two-byte addresses within a secondary are stored in big-endian format, which is the opposite of the 6502's native little-endianness. Here's a hopefully improved partial inner interpreter implementation
; instruction pointer takes up 3 zero page locations
iplo
   .byt   0
ip
   .word $0400
page
   inc ip+1
next
   inc iplo
   ldy iplo
   lda (ip),y
   bmi token
direct
   pha
   iny
   sty iplo
   lda (ip),y
   pha
   rts
token
   tay
   lda tokenh-128,y
   pha
   lda tokenl-128,y
   pha
   rts
tokenh
   .byt >(page-1)
tokenl
   .byt <(page-1)
PostPosted: Wed Dec 07, 2016 5:24 pm
Instead of making a 128/128 split, you could also start out with 256 single-byte codes. As the table gets full, the last entry is set to point to a secondary dispatcher using a new table.
PostPosted: Wed Dec 07, 2016 5:51 pm
This all-token model makes more sense for an unexpanded VIC-20 (5K) than a maxed-out PET (32K) which neatly divides the RAM from the ROM + I/O at the 32K boundary.
Including the Assembler and a bunch of other stuff that won't be in the final edition, PETTIL has about 600 words in it right now (approximately 5 screens, 5 columns, 25 lines per screen). Even a minimalist Forth plus any application code would push a 256 token limit. It's pretty easy to add a token that treats the following two bytes as an address.
One could even use the BRK instruction as a way to toggle back and forth (get it?) between separate 8-bit and 16-bit NEXT routines, e.g. token1 token2 token3 00 addr1 addr2 00 token1 ...
PostPosted: Wed Dec 07, 2016 7:19 pm
Heck, make the "long token" signifier $00 and you can just short-circuit the dispatch routine with a BEQ when it's loaded from memory. (Or, if you're doing the 128/128 split, a BMI - depends on whether you want your long tokens to be two bytes or three, I suppose.)
PostPosted: Thu Dec 08, 2016 7:59 am
If "long tokens" are more rarely executed than short tokens, it makes sense to keep the fast path fast, and not have extra checks whether or not to branch out. Nested dispatches keep the outer dispatch as lean as possible.
PostPosted: Thu Dec 08, 2016 9:52 am
Yes, that's exactly what I was thinking. Most likely the first 250 or so tokens are executed much more frequently than the rest. They are also likely smaller so the relative gain of a few cycles matters more.
PostPosted: Thu Mar 09, 2017 8:22 pm
Part 3 of the series is up...
I've made use of the wonderful resources at 6502 org, particularly the idea of splitting the instruction pointer (called gIp in my implementation) into a page offset and using the Y register to hold the byte offset: it really does improve the performance of the core Next function.
