It is currently Sat Nov 23, 2024 7:43 pm
PostPosted: Mon Feb 06, 2006 5:27 pm
..."Direct Zero Page" (DZP) register? It can!!
Hey! The '816 does it so why can't our little buddy the '02?
I love the zero page. I hate the fact that it is always in the same place. With some ingenuity (not really), this fantasy can become reality.
Imagine, if you will, a latch. A latch that holds the upper 8-bits to be used with zero page accesses. A latch that has it's output enable activated by the high byte of the address being equal to zero. There must needs be a bus transceiver (or whatever) to gate the original high 8 CPU address lines.
The software just writes to this latch when it wants to change the DZP location. Anytime logical page zero is accessed, the physical page number in the latch is used instead. This can make things like 256-byte circular buffers fun. Of course, it may all be entirely superfluous.
For more fun add another latch and drive the output enables based of the high address byte being zero and also the read/~write CPU output. One latch is used for DZP reads, the other for DZP writes. In my thinkery, this dual-latch setup has more dubious benefits. I thought it would mainly be used to help speedup memcpys, but the cycle cost of other addressing modes is the same as zeropage indexed, for example.
I'm surely not the only person to have thought of this, but here it for comments and discussion. What do you think? Could this be useful and for what? Is it unnecessary?
Thanks for playing.
-- Lord Steve
PostPosted: Mon Feb 06, 2006 9:09 pm
Cute idea. You could do the same to move the stack around, or make it smaller. Useful for multitasking.
Something else I thought of while considering this sort of thing: is there any way to determine when the CPU is doing an instruction fetch (rather than just normal data)?
If there is, you could record the instruction. If its a stack access (PHA and friends), you could actually a seperate chunk of memory, thus giving a page back to the program.
Take this further, and you could have zero page in a seperate bit of memory too (ie LDA $00 is different to LDA $0000). Not sure if there's value in that.
We're starting to get into MMU territory here. Thanks for your post, its started a whole new topic in my notebook of things to try and implement one day :P
PostPosted: Mon Feb 06, 2006 10:45 pm
I would like to point out that, IIRC, the Commodore 128's MMU chip did support moving zero and stack pages around in memory, though I don't think it was used often.
The _SYNC signal is asserted when fetching an opcode byte. It is not asserted when fetching operand bytes however.
The 65816 has better disclosure of its intentions, as it replaces the _SYNC signal with VPA and VDA signals:
VDA VPA Operation
 0   0  Internal operation; no valid bus cycle.
 0   1  Fetch from program space: operand bytes
 1   0  Fetch or store from/to data space
 1   1  Fetch from program space: opcode byte
BTW: VDA stands for Valid Data Access, and VPA stands for Valid Program Access.
 Post subject: Stack moving
PostPosted: Tue Feb 07, 2006 10:24 pm
Being able to mov the stack around is an even more awesomer idea. Pushing a register only takes 3 cycles, including incrementing SP. That is, of course, cheaper than storing then incrementing a pointer.
Come on, you guys... more ideas!
Thanks for playing.
-- Lord Steve
PostPosted: Tue Feb 07, 2006 10:37 pm
Interesting. So if you swap in/out different bits of memory depending on the opcode. eg a flip-flop that is set when the opcode is PLA and friends, and cleared on everything else, then use its output to drive CS lines on different memories, giving a "private" stack area. Not sure what practical use there is for this though - most of the time a bigger memory chip would yield the same end result (more RAM available).
And I guess you could do paging by watching for a memory-access opcode, then watching for the next two bytes (zeropage & stack as special cases). Then, do the page table lookup and fire a NMI to get the OS to load something useful. Then I think you'd need the ISR to tweak the stack such that after the RTI the op that did the memory access is executed again.
Or you could possibly halt the main processor and have the coprocessor (since we're getting into that kind of complexity) do the work of pulling in the data from disk or whatever.
All of this seems horribly complicated for something that is fairly useless when its so easy to fill the entire address space with actual RAM (unlike a "real" virtual memory scheme, when you rarely have many GB of actual RAM).
Maybe I'll play with it sometime, for the educational value.
That would make things quite a bit simpler. The 65816 has a larger address space too, right? A real MMU would make far more sense in this case.
PostPosted: Wed Feb 08, 2006 12:19 am
Yep. Note that multi-byte operations (most 2-byte and 3-byte instructions) only have _SYNC asserted on the first byte; it's negated on the other two bytes. Therefore, your MMU circuitry would need to properly track this.
The early Sun workstations (which used only 68000s) did this, because the 68000 lacked any facility to properly restart an instruction. It wasn't until the 68010 that this capability came about.
Likewise, the 6502 lacks restartability; however, the 65816 exposes an _ABORT pin, which if asserted, causes the current instruction to abort, generates an interrupt with the return address set to the aborted instruction -- thus, it allows proper instruction restarting.
Yes, the 65816 supports 16MB address space, provides better support for multiple address spaces, and provides for instruction restartability via the _ABORT pin.
PostPosted: Wed Feb 08, 2006 1:18 am
Separating data access for "PHA and friends" from that of other instructions would forfeit the 6502 stack-relative addressing methods presented by Blargg and Bruce. The hardware would have to be built up special anyway since the extra latches and so on needed to do the job don't exist on normal 6502 computers; so you might as well go with the 65816 which makes these things so much easier. The '816 doesn't have to be any harder to implement hardwarewise than the '02. I think the high address byte latching scares some people away; but remember you don't have to latch, decode, or use A16-A23 if you don't need more than 64K of address space. The '816 will still give you a ton of benefits over the '02; and if you're often dealing with 16-bit numbers, the '816 is much easier to program.
For multiple stacks for multitasking on the 6502, your software can save and restore a stack pointer for each task. Since there's only a 256-byte space to work with, you'd divide that up into equal segments, giving each task its own segment. No extra hardware is needed. From my experience, you could go with three or four tasks easily enough in Forth, and maybe six with care. A lot of assembly-language applications might be able to go quite a bit higher. Some people have thought the 6502's 256-byte stack space is extremely limited; but remember some microcontrollers only give you 6 (or even fewer!) stack levels, meaning that if you're that many subroutine levels deep and an interrupt hits, you overflow the stack. A lot of them don't let you put anything else on it either.
PostPosted: Wed Feb 08, 2006 5:49 am
The ATmega series uses data RAM for the stack.
However, even so, you don't need multiple stacks to multitask! Remember that multitasking is a user-perception. (Footnote: Contrast this with multithreading, which is not a user perception -- it's an implementation technique to achieve multitasking.) Another approach to achieving multitasking is through event-driven programming, which often out-performs even cooperative multitasking because it does away completely with its task switching overhead.
See http://en.wikipedia.org/wiki/Event-driven_programming for a simple introduction to the concept if you're unfamiliar with it. For a more detailed explanation (only 59 pages) see http://eventdrivenpgm.sourceforge.net/ . To see event driven programming in action, see the uIP TCP/IP stack at http://www.sics.se/~adam/uip/ .
PostPosted: Thu Feb 09, 2006 9:19 pm
A related topic got started at Hardware --> "Homebuilt" 6502 cpu's at http://www.6502.org/forum/viewtopic.php?t=44 , daydreaming about new instructions to add to a 6502, and about actually making one's own processor.
Ruud has been working with a few others at making a 32-bit 6502. Recently their progress has been slow due to other demands of life, and the forum for that has been dormant; but I guess the project is still on. I'll apologize again to Ruud for getting his last name wrong in the above-mentioned page. I guess he had signed off with "Groetjes, Ruud" in a post and I took that to be a last-name-first notation. His last name is Baltissen. 'Groetjes' is Dutch for 'Regards'.
PostPosted: Sat Dec 30, 2006 8:52 pm
Hi,
I have implemented a real MMU with my CS/A computer http://www.6502.org/users/andre/csa that can remap each 4k separately into a 1M address space. This way the zeropage as well as the stack are moved together "from under the CPU" and can be replaced for every task.
The GeckOS operating system http://www.6502.org/users/andre/osa can use this MMU, but can also split the stack for multiple tasks in an MMU-less system (like the C64).
And, upcoming January, is a CS/A board (with a 6502) that halts the main 6502 CPU when a bus error occurs and takes over the bus to resolve the bus error.
The upcoming board uses this feature to "trace" the main 6502, in that it halts the CPU on each opcode fetch and records the opcode address.
André
