Mike B.
One thing is for sure... every single hand wired IC will be visible behind glass in some kind of hand made, back-lit wood cabinet.
I will probably go for a desktop piano configuration, with the VGA monitor built in where the sheet music stand might usually go.
Beside the monitor will be vertical columns of populated boards, nicely back-lit, and with many colored status LEDs blinking away.
Did a bit more figuring tonight, and decided to change the way the Sample Memory works.
Rather than 512K for each of the 8 voices, I am going with a single huge 8MB Sample Memory (512K x 16).
A high speed 8 channel multiplexer will swap the counters to the memory to fetch 8 samples at a time.
This way, I can assign up to 256 different samples in the huge memory, and play any 8 of them at once.
At a sample rate of 32Khz, this is 256 seconds of sample time... more than enough for a diverse number of samples.
To make this work, I just need to toss another 48 registers (74HC574) and a dozen multiplexers at it!
Did I mention that "Chip Count" is of no concern to me?
Brad
