It is currently Fri Nov 22, 2024 6:58 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Mon May 30, 2016 7:45 am
AWJ wrote:
If it isn't too much trouble, could you please repeat the exact same test, only with an XBA (a one-byte, three-cycle instruction) in place of the TXY? Again, assert /IRQ during the fetch of the XBA.
It looks like the same thing.  I added a NOP between the CLI and the interrupted XBA instructions just to make sure it behaved the same.  (It was the same with and without the NOP.)
PostPosted: Mon May 30, 2016 8:05 am
More difficult is preventing "forbidden" instructions from being executed. The ideal time to assert /ABORT would be on the opcode fetch cycle, which would assure that the instruction can't alter a register or memory.
Just checked the datasheet for the descriptions of ABORTB. Certainly not a model of clarity! See below.
It's not clear to me how memory writes are affected by abort, if at all.
However, the timing window is small, as the opcode can only be examined during Ø2 high, which is also when /ABORT would have to be asserted.
My reading of the datasheet says that would be too late: ABORTB has to be stable before the rising edge of phi2.
Asserting /ABORT on the second Ø2 cycle might be too late in some cases to prevent errant operation.
Do we know this by experiment, or is it a suspicion?
The datasheet (Sep 2010) makes it clear that ABORTB has a setup time before the rising edge of phi2 and a hold time after the falling edge of phi2. It also says that ABORTB should only be asserted for a single cycle. It says that ABORTB is latched internally and that the current instruction completes but processor state is not updated. Table 5-7 ("Instruction Operation") contains annotations for a few instructions as to the last cycle in which ABORTB can be applied - there's no statement as to the earliest cycle and the implication that for all other instructions even the last cycle of the instruction is still a valid time to signal an abort.
The datasheet doesn't say what happens to memory writes - does the instruction still perform the expected memory writes or does it convert them to reads?
My feeling is that ABORTB is designed only to suppress the updating of internal state - suppressing memory writes is the responsibility of the memory subsystem. In the intended use, to signal an address fault, it is as you say: the address responsible for the abort becomes valid during phi2 low, and ABORTB should be asserted within that same phase, to meet the setup time constraint against the phi2 rising edge.
According to that, it would be fine to assert ABORTB in the second cycle of any instruction (other than an interrupt sequence.) With the possible exception of WAI, which isn't annotated. Has there been an experiment with aborting WAI?
PostPosted: Mon May 30, 2016 8:26 am
Ed, I can try what you want to find out.  I don't have any way to test for ns of set-up or hold time, but tell me, in extreme detail, what order you want things in for the test sequence.  The way the fixture is controlled and read, there will be a minimum of quite a few microseconds between edges, but I can lower the clock, bring ABORT\ down, raise the clock, put an op code on data on the bus, etc., and print a line of status at every step of interest, which could be as many as four lines per clock cycle.  (Actually it could be a lot more than four, but there's probably no point.)
BDD asked me (by email) to try that (over a week ago), and here's what I got (and wrote to him):
    As soon as Φ2 went up in the first cycle after reading the WAI op code, ie, in the second cycle of the WAI instruction, the processor pulled RDY down.  Then before the fall of Φ2 in that second cycle of the WAI instruction, I pulled ABORT low, but it did not respond.  [It was already asleep.]
    I never really thought about it, but now I know why they say to set the interrupt-disable bit I before doing a WAI.  If you don't set I, the same interrupt that wakes it up out of WAI also starts the interrupt sequence.  The first cycle reads and discards the op code at the address that was up next to execute.  (I tried LDA #$A9 and it didn't even fetch the operand.)
PostPosted: Mon May 30, 2016 8:36 am
I think this is outside the spec: ABORTB is only allowed to change during phi2 low. It must be stable throughout phi2 high. Please could you redo this experiment (aborting WAI in the second cycle) with that in mind? It means pulling ABORTB low during phi1.
PostPosted: Mon May 30, 2016 8:38 am
Hmm, it's not exactly the same, is it? There's still the opcode fetch at the start of the interrupt sequence, but neither of the dead bus cycles of the XBA mutates into a spurious operand fetch. It looks like that particular quirk is limited to two-cycle instructions.
I just noticed that the cycle breakdown of the hardware interrupt sequence in the 65816 datasheet contradicts itself. The "data bus" column describes the first cycle of the sequence as "I/O" (i.e. dead bus), but the VPA and VDA columns indicate that both are high (as in an opcode fetch). Evidently the VDA and VPA columns are correct and the data bus column is wrong.
Thanks again for your help!
PostPosted: Mon May 30, 2016 8:44 am
Ah, you're right.  I looked at the wrong thing when comparing.
PostPosted: Mon May 30, 2016 8:56 am
Pulling ABORT\ down during Φ1 of cycle 2 of WAI, the processor did not respond to the ABORT\ signal.  It went to sleep.
PostPosted: Mon May 30, 2016 8:59 am
Thanks. WAI might be a difficult case then. For BDD's purposes, it might be necessary to detect and tweak the opcode during the fetch cycle, which will eat into the memory access time and potentially limit the clock speed of the system.
PostPosted: Mon May 30, 2016 5:31 pm
Could you test the following four cases, each time asserting /IRQ during the operand fetch of the BCS instruction?
1) An untaken branch (CLC; BCS)
2) A taken branch (SEC; BCS) in native mode
3) A taken branch in emulation mode that does not cross a 256-byte page
4) A taken branch in emulation mode that does cross a 256-byte page
I'd like to know in which cases the interrupt is taken immediately after the BCS and in which cases the 65816 executes another instruction first.
According to Visual6502, a 6502 will only take the interrupt immediately if the branch is taken and crosses a 256-byte page (making the branch instruction take 4 cycles); otherwise it executes one more instruction first. To guarantee the interrupt is taken before the next instruction, the interrupt line must go low during the opcode fetch of the branch instruction. I'd like to know whether the 65816 is the same, and whether it varies between native and emulation modes.
PostPosted: Mon May 30, 2016 7:35 pm
Actually, "I/O" in the operation table doesn't automatically mean a "dead bus" cycle. "I/O" means "internal operation," during which the buses may or may not be "valid." It's my opinion that "I/O" merely indicates that the state of the data bus is a "don't care" as far as the '816 is concerned. If memory and input/output hardware selection is being qualified by VDA and VPA, the state of the data bus during Ø2 high should never be an issue.
The address and data buses are driven on every cycle of every instruction, and as long as the expression VDA || VPA is true, the address bus will contain a valid address and the data bus will contain a valid bank address during Ø2 low. The data bus content during Ø2 high may be garbage or valid data, but that in itself is not defined by the VDA and VPA outputs (recall that those signals mean "valid data address" and "valid program address," respectively, so they only annunciate if the '816 is generating a valid address).
I essentially agree, although it may be that an "on the fly" opcode change as a consequence of thwarting the execution of a forbidden instruction would not necessarily affect overall performance. CPLDs and FPGAs are generally sub-10ns devices, so even at 20 MHz there could be enough time for the logic to intercede and convert a forbidden instruction into something harmless whilst toggling /ABORT. Needless to say, the timing analysis would be interesting to carry out. :D
I'm thinking that an errant WAI wouldn't be too much an issue as long as IRQs are enabled and a periodic interrupt is occurring, e.g., a timer IRQ, which most systems would have. All that would happen would be a little execution time would be squandered as the '816 was waiting for the next interrupt. Also, WAI can be indirectly detected in hardware, since the '816 (and the 65C02) pulls the RDY pin low while WAIting. To quote from the data sheet:
    2.24 Ready (RDY)
    The Ready is a bi-directional signal. When it is an output it indicates that a Wait for Interrupt instruction has been executed halting operation of the microprocessor. A low input logic level will halt the microprocessor in its current state. Returning RDY to the active high state releases the microprocessor to continue processing following the next PHI2 negative transition. The RDY signal is internally pulled low following the execution of a Wait for Interrupt instruction, and then returned to the high state when a RESB, ABORTB, NMIB, or IRQB external interrupt is active. This feature may be used to reduce interrupt latency by executing the WAI instruction and waiting for an interrupt to begin processing. If the IRQB Disable flag has been set, the next instruction will be executed when the IRQB occurs. The processor will not stop after a WAI instruction if RDY has been forced to a high state. The STP instruction has no effect on RDY. The RDY pin has an active pull-up and when outputting a low level, the pull-up is turned off to reduce power. The RDY pin can be wire ORed.
(Emphasis added.)
In my POC V2 design, RDY is attached to a CPLD pin so the CPLD can imposed a wait-state during ROM or I/O block accesses. Under normal operation, that CPLD pin is kept in the high-Z state so it doesn't interfere with the MPU's manipulation of RDY. However, since the data sheet says that the '816 won't halt on a WAI if RDY is continuously driven high (which implies, by the way, that there's no threat to the MPU's health if RDY is actively driven high when WAI is executed), continuously driving RDY high at all times when a wait-state isn't needed and the system is operating in user mode (as opposed to kernel mode, where WAI would be an acceptable instruction) would provide automatic protection, even in the case where IRQs have also been disabled.
PostPosted: Tue May 31, 2016 9:50 pm
AWJ wrote:
Could you test the following four cases...
Hopefully I can get to that in the next couple of days.  I need to get a PCB finished for work now.
I personally have zero interest in running the '816 in emulation mode, but I realize that commercially made home computers and game systems that used the '816 were pretty much forced by market requirements to be able to run 6502 code.
PostPosted: Wed Jun 08, 2016 5:05 am
Ok, here they are.
#1 from three posts up:
After a branch that will not be taken is interrupted in the operand-fetch cycle, one more instruction is executed before the interrupt sequence starts.
#2:
After a branch that will be taken is interrupted in the operand-fetch cycle, no more instructions are executed before the interrupt sequence starts.
[Edit, 6/22/16] I tried the same thing but branching across a page boundary, and it did not change anything.  Even the cycle count on the branch was the same.
#3:
With the '816 in '02-emulation mode, after a BCS taken to the same page is interrupted in its operand-fetch cycle, the interrupt sequence starts without another instruction being executed first.
#4:
With the '816 in '02-emulation mode, after BCS is interrupted in the operand-fetch cycle and it will branch to another page, the interrupt sequence started before another instruction was executed.
If I made any mistakes in the comments, you'll figure it out in the printouts.
PostPosted: Fri Jun 10, 2016 6:29 pm
Ok, here they are.
Thanks! So the 6502's quirky interrupt check timing during taken branches is not duplicated by the '816, even in emulation mode. I guess emulation mode is kind of a "best of both worlds" of the 6502 and 65C02--decimal mode adc/sbc don't take an extra cycle (like they do on the 'C02) and RMW instructions still write back the unmodified data during the cycle that's an I/O cycle in native mode (this quirk was removed in the 'C02, but there were apparently hardware and drivers that depended on it) but otherwise the '816 fixes the same quirks and bugs that the 'C02 does.
PostPosted: Fri Jun 10, 2016 8:51 pm
That had to change to accommodate the possibility of an abort interrupt. Abort is meant to force a restart of the same instruction if a memory access error, e.g., a page fault, occurs. If the '816 were allowed to take the branch before acknowledging /ABORT the entire purpose of being able to "abort" an instruction would be defeated.
I guess emulation mode is kind of a "best of both worlds" of the 6502 and 65C02...
Not exactly. None of the NMOS behavior is present in a way that will affect the rest of the system as long as the interface between the 65C816 and the buses is correct. This includes the proper use of VDA and VPA to qualify all bus cycles, which is something that is unambiguously stated in the Caveats section of the '816 data sheet.
...and RMW instructions still write back the unmodified data during the cycle that's an I/O cycle in native mode...
Again, completely avoidable by proper use of VDA and VPA. The "false" data bus access during cycle 5 (8 bit accumulator) or 6 (16 bit accumulator) of any R-M-W operation is indicated by the expression VDA || VPA being false.
Edit: I incorrectly typed VDA && VPA instead of VDA || VPA.
Last edited by BigDumbDinosaur on Sat Jun 11, 2016 12:38 am, edited 1 time in total.
PostPosted: Fri Jun 10, 2016 9:11 pm
Again, completely avoidable by proper use of VDA and VPA. The "false" data bus access during cycle 5 (8 bit accumulator) or 6 (16 bit accumulator) of any R-M-W operation is indicated by the expression VDA && VPA being false.
Yes, but in emulation mode it's a unique "false write cycle" rather than a "false read cycle". It's the only time ever that VDA is false but WR is true. So hardware that depends on the false write for some reason will work if WR overrides VDA, or if VDA isn't used at all (e.g. a 65802 dropped into a legacy 6502 board)
