It is currently Sun Nov 24, 2024 3:55 am
Post new topic Reply to topic  [ 52 posts ]  Go to page Previous  1, 2, 3, 4
 Post subject: Re: ACIA sense check
PostPosted: Sat May 07, 2016 4:19 am
banedon wrote:
OK. I've rewritten the variable detection and processing routine in my assembler and now things seem a little better:
I'm off to bed so will re-assemble and test my sprint code tomorrow.
Just a curmudgeonly opinion, but an assembler that conforms to the MOS Technology assembly language syntax might be less a hassle. Standards do exist for a reason, y'know, and the MOS Technology syntax has proven itself over the years to be straightforward and unambiguous.
I don't know what it is that prompts the development of assemblers and compilers that deviate from published standards. What I do know is that such deviation often causes unnecessary portability problems. Case in point: C. As long as C compilers followed the K&R standard everything was fine. Then all sorts of strange compilers started coming out of the woodwork during the early MS-DOS days, and code portability became dodgy. That was what prompted the development of an ANSI C standard.
PostPosted: Sat May 07, 2016 8:29 am
The attachment foundtheissue_resolved.gif is no longer available
I completely see your point and agree for the most part. However, when I first started writing 65C02CA I didn't know of any real standards and now I'm "almost there" with regard to completion I really don't feel like redoing it.
Also, I was trying to emulate the assembler found in the BBC Micro B+ as that is the machine that I had in my formative years and enjoyed using. I've sort of wondered away from that to allow things like $ as well as & for hex character designations and allowing % to designate a binary number (never part of BBC Basic Assembler) and other tweaks. Another factor is that I made 6502CA for myself, although I would be very happy indeed if anyone else find a use for it.
BTW (here comes the icing on the cake) - I found another bug.
See if you can spot it :mrgreen: :
I've left a small pointer/clue in there and it explains exactly why LDY (zp),Y does not work (currently).
PostPosted: Sat May 07, 2016 8:59 am
Ok issue fixed and it was caused by the omission of one line of code. I'm going to go through and re-check all assembler modes as a precaution.
Another issue I found (on a slightly different but related note) I also found a fault on my Bus Monitor V4 so that A15 and A14 were misreporting. Fixed.
Talk about a bit of a self inflicted train wreck, but you (or me in this instance) live and learn and now all issues found have been fixed in short order :oops: :roll: .
PostPosted: Sat May 07, 2016 3:55 pm
Nothing wrong with following the convention of your choice - the Beeb has many active adherents!
PostPosted: Sat May 07, 2016 4:33 pm
Indeed :).
BTW, I thought writing 0 to the status flag reset the ACIA, but it doesn't seem to.
If I reset the uP it will sometimes write rubbish to the COM port and I suspect it's because of corrupted comms due to the reset, although I'm not sure. All subsequent comms then seem to be rubbish so I suspect that the output transmissions are out of phase. Incoming transmissions are fine after a couple of bytes of rubbish.
I know that writing 0 to the status register resets some of the IC, but some flags get left behind. Looking into it by... re-reading the manual lol.
PostPosted: Sat May 07, 2016 6:38 pm
The data book says that writing anything to the status register does a programmed reset but that it's not as complete as a hardware reset. Just make it a habit to set everything up before getting going and not assume things.
PostPosted: Sat May 07, 2016 7:16 pm
A have as far as I'm aware and it does work - until a reset. The 65c02 runs exactly the same ACIA setup code after reset as it does on power up.
Users browsing this forum: No registered users and 47 guests
