It is currently Sat Sep 21, 2024 11:20 pm
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
PostPosted: Fri Apr 15, 2016 4:49 am
rwiker wrote:
pnoyes wrote:
I have been doing a lot of 6502 assembly programming. Last night I went back to doing some C programming and I needed to comment out some code. I commented it out, compiled, and to my surprise it was still running as before. I then spent a good 20 minutes trying to figure out why commented out code could still possibly run.
It turns out I used a semicolon in the C code for the comment instead of //. Prepending a line in C with a semicolon does not produce a compile error.
Anyone else mix this up?
Interesting that the compiler didn't issue a diagnostic with the semicolon at the start of the line. Which compiler is this?
Why should a C compiler complain about a semicolon at the start of a line? Keep in mind that the canonical string copy routine in C is something like
void strcpy(char *d, char *s) {
 while (*d++ = *s++)
The semicolon in the middle of the strcpy while loop works because it is on an otherwise blank line, which automatically makes it the terminating character.
Not quite... the semicolon is a statement terminator, and in this case terminates a null statement. Being able to make a null statement stand out in the source code is useful, and not something that you want the compiler to complain about.
PostPosted: Fri Apr 15, 2016 6:10 am
You're splitting hairs.
PostPosted: Fri Apr 15, 2016 6:50 am
I'm not a great C programmer, but FWIW I can vouch for rwiker's description of the semicolon issue. White space, including line breaks (or the lack thereof) carry far less importance than semicolons in C and C++ source, allowing some misleading or confusing constructions at first glance (or even second glance), because many of us as humans have a tendency to see them as being in the same "ball park" of significance. In my experience, most assemblers tend to share that view. Most C compilers certainly do not.
Mike B.
PostPosted: Fri Apr 15, 2016 8:10 am
Mike B.
Whitespace is largely ignored in C. If you look at examples of obfuscated C programs they are often have either minimal whitespace and most of the code is on very long lines, or they use lots of redundant whitespace to format the code into an interesting shape.
http://www.ioccc.org/2015/burton/prog.c
You could rewrite the strcpy example as ...
void strcpy(char*d,char*s){while(*d++=*s++);}
... and it would still work. The only mandatory whitespace in this example is between the return type and the function name.
The C grammar defines an 'expression-statement' as and optional 'expression' followed by a semicolon. A 'while' statement is defined as 'while ( expression ) statement' where 'statement' expands into a choice of several types of statement including the 'expression-statement'.
Andrew Jacobs
PostPosted: Fri Apr 15, 2016 9:18 am
Actually whitespace is compulsory only around keywords and variable names, when a special symbol such as '(' is not used. This is obvious, as ina=3; doesn't mean the same thing as int a=3;
It can also be compulsory in pre-processor directives.
cron
