It is currently Fri Nov 22, 2024 3:11 am
Post new topic Reply to topic  [ 19 posts ]  Go to page Previous  1, 2
PostPosted: Mon Jan 11, 2016 6:28 am
theGSman wrote:
... I'm sure that much greater optimizations can be achieved but that would take a lot of further research and I already have something that works a treat ...
I stewed for many hours cooking the UM/MOD and UD/MOD further down in that thread. I don't have a 6502 Forth handy to do the speed comparison, but I'm willing to bet you a soda pop that mine will beat yours slightly for speed and significantly for size.
Mike B.
PostPosted: Mon Jan 11, 2016 6:50 am
Since you don't use the X or Y registers in the main loops, you might consider saving the length value in them. Updating is quicker and shorter; you can also do it before updating the pointers so as not to waste time doing that if it's not necessary (not a big deal overall, more of a neatness thing). You'll have to put the length values in those registers, which is an opportunity to check if the initial value is zero:
; initialize length
; - Z-flag set if no length, clear if at least one byte
INI_LEN:
    ldx lenl
    ldy lenh
    bne +
    txa
+   rts
; update length, source and target pointers
; - Z-flag set if done, clear if not done
UPD_STL:
    txa        ; update length
    bne +
    tya
    beq done   ; no more to do
    dey
 +  dex
    inc srcl   ; update source pointer
    bne +
    inc srch
 +  inc tgtl   ; update target pointer
    bne done
    inc tgth   ; warning: sets Z-flag if rollover from $FFFF to $0000
done:
    rts
If you didn't want to disturb the A register in these routines, you could replace all the "t-a" instructions with "cp- #$00". Adds three bytes overall but no time.
PostPosted: Mon Jan 11, 2016 8:47 am
You'd win that bet hands down. At the time I dreamed up the algorithm and method of achieving it, I'd never heard of the concept of gradually shifting the dividend out and the quotient/remainder in.
I will definitely have to examine your code in more detail some time.
PostPosted: Mon Jan 11, 2016 11:38 am
I've updated the UPD_STL routine and it's now 21 bytes in size, a savings of 5 bytes.
UPD_STL   INC   SRCL   ;Increment source low byte
         BNE   UPD_TL   ;Check for rollover
         INC   SRCH   ;Increment source high byte
UPD_TL   INC   TGTL   ;Increment target low byte
         BNE   DECLEN   ;Check for rollover
         INC   TGTH   ;Increment target high byte
;DECLEN subroutine: decrement 16-bit variable LENL/LENH
DECLEN   LDA   LENL   ;Get length low byte
         BNE   SKP_LENH   ;Test for LENL = zero
         DEC   LENH   ;Else decrement length high byte
SKP_LENH   DEC   LENL   ;Decrement length low byte
         RTS   ;Return to caller
The memory move and memory fill routines have the stayed the same at 15 bytes each. I rewrote the compare routine so it handles the EEPROM writing based on a flag setting. It no longer requires the JSR/RTS to the error routine which prints the failed address. This resulted in the compare routine being 9 bytes larger.
COMPLP   LDA   LENL   ;Get low byte of length
         ORA   LENH   ;OR in High byte of length
         BEQ   QUITMV   ;If zero, nothing to write
         BIT   TEMP2   ;Check for EEPROM programming
         BPL   SKP_BURN   ;If bit 7 not set, skip it
         JSR   BURN_BYTE   ;Else Burn a byte to EEPROM
SKP_BURN   LDA   (SRCL)   ;Else load source
         CMP   (TGTL)   ;Compare to source
         BEQ   CMP_OK   ;If compare is good, continue
         LDA   TEMP2   ;Get EEPROM flag
         ORA   #$40 ;Get bit 6 mask for error
         STA   TEMP2   ;Store to flag to show error in EEPROM write
         JSR   SPC2   ;Send 2 spaces
         JSR   DOLLAR   ;Print $ sign
         LDA   TGTH   ;Get high byte of address
         LDY   TGTL   ;Get Low byte of address
         JSR   PRWORD   ;Print word
         JSR   SPC   ;Add 1 space for formatting
CMP_OK      JSR   UPD_STL   ;Update pointers
         BRA   COMPLP   ;Loop back until done
The EEPROM write routine was rewritten to simply set the flag, call the compare routine and check the flag for an error on return to print the appropriate message before exiting. This saved 20 bytes of code.
PROG   LDA   #$80   ;Get EEPROM write active mask
         STA   TEMP2   ;Set flag for COMPLP routine
         JSR   COMPLP   ;Call routine to write/compare
         BIT   TEMP2   ;Check for error bit in flag
         BVC   PRG_GOOD   ;Branch if no errors
         LDA   #$26   ;Get Prog failed message
         BRA   BRA_PRMPT   ;Branch to Prompt routine
PRG_GOOD   LDA   #$25   ;Get completed message
         JSR   PROMPT   ;Send to console and exit
         LDA   #$27   ;Get warning message for RTC and Reset
BRA_PRMPT   JMP   PROMPT   ;Send to console and exit
Since starting this thread, between the core routines here plus two others which increment and decrement another 16-bit pointer, I've reduced code by 27 bytes. I'm still looking at some other options and can likely save a few more bytes by putting the length check for zero in the UPD_STL routine, but it needs to check on entry and confirm on exit to work with the existing routines.
