It is currently Sat Nov 16, 2024 8:42 pm
PostPosted: Sat Jul 30, 2005 9:28 pm
Source code is in MERLIN format be should be easy to adapt
    1 * String Comparison Routine for PASCAL strings
    2 * INPUT *
    3 * Pointer to First String in STRING1, STRING1+1
    4 * Pointer to Second String in STRING2, STRING2+1
    5 * STRING1 and STRING2 must be located on the ZERO PAGE
    6 * TEMP can be anywhere in memory
    7 * OUTPUT *
    8 * If String1 < String2 then carry clear; else carry set
    9 * If String1 = String 2 then Z set; else Z clear
   10 * Destroys A-REG and Y-REG; X-REG unchanged
   11 STRING1  EQU   6
   12 STRING2  EQU   8
   13 TEMP     EQU   9
   14 PSTRCMP  LDY   #0
   15          LDA   (STRING1),Y
   16          CMP   (STRING2),Y
   17          BCC   :1
   18          LDA   (STRING2),Y
   19 :1       STA   TEMP
   20          LDY   #1
   21 :2       LDA   (STRING1),Y
   22          CMP   (STRING2),Y
   23          BNE   :3
   24          INY
   25          CPY   TEMP
   26          BCC   :2
   27          LDY   #0
   28          LDA   (STRING1),Y
   29          CMP   (STRING2),Y
   30 :3       RTS
A slightly shorter and faster 65C02 version of this code can be created by removing lines 14 and 27, and removing the ",Y" from the end of every line EXCEPT 21 and 22.
PostPosted: Sat Jul 30, 2005 9:33 pm
Also, if any one can modify this routine to deal with C style Strings of any length I would greatly appreciate seeing it.
PostPosted: Sun Jul 31, 2005 3:07 pm
Untested... (in ACME syntax)
T0 = $00
T1 = $02
T2 = $04
strcmp:
   ; T0 = input string 1 (255 chars or less)
   ; T1 = input string 2 (255 chars or less)
   ; on exit, flags should be set as expected for CMP.
   ;  C flag clear if string 1 < string 2
   ;  Z flag set if string 1 = string 2
   ; I treat all registers as effectively destroyed.
   ;  A is trashed outright.
   ;  X is untouched, but should never depend on that anyway.
   ;  Y contains length of shortest string, less the NULL.
   ;    (same semantics as strlen()).
   ldy #$00
.loop:
   lda (T1),y
   beq .different   ; Terminating NULLs always break the loop
   lda (T0),y
   cmp (T1),y
   bne .different   ; Mismatches also break the loop
   iny
   jmp .loop
.different:
   lda (T0),y   ; reset the flags accordingly
   cmp (T1),y
   rts
; As a bonus: strlen -- get length of string, excluding NULL byte.
; Since we're relying on strcmp() to get the length, it's not as fast
; as a native implementation of strlen(), and it destroys T1 too.
strlen:
   lda T0
   sta T1
   lda T0+1
   sta T1+1
   jmp strcmp
PostPosted: Mon Aug 01, 2005 4:57 am
In the length-byte-before-string comparison routine above:
1. With the EQUs above, TEMP overlaps with the high byte of the STRING2 pointer.
2. It doesn't compare the last byte of the string when the length byte is greater than 1.
3. If both length bytes are $00, it can loop endlessly.
A couple of optimizations are also possible: (a) X can be used instead of TEMP, and (b) the LDY #1 can be eliminated. Here is the updated code:
   LDY #0
   LDA (STRING1),Y
   CMP (STRING2),Y
   BCC :1
:1 LDA (STRING2),Y
   TAX
   BEQ :3
:2 INY
   LDA (STRING1),Y
   CMP (STRING1),Y
   BNE :3
   DEX
   BNE :2
   LDA (STRING1,X)
   CMP (STRING2,X)
:3 RTS
Here is a slightly optimized version of the routine that compares strings (of any length) terminated by $00. Same inputs and outputs as above.
   LDY #0
:1 LDA (STRING1),Y
   BEQ :2
   CMP (STRING2),Y
   BNE :3
   INY             ; note: C=1 since CMP was equal
   BNE :1
   INC STRING1+1
   INC STRING2+1
   BCS :1          ; always branches
:2 CMP (STRING2),Y
:3 RTS
Users browsing this forum: Google [Bot] and 5 guests
