It is currently Sun Nov 24, 2024 5:46 am
Post new topic Reply to topic  [ 135 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9
 Post subject: Re: Star Ground
PostPosted: Thu Dec 31, 2015 5:02 am
banedon wrote:
It is possible that the GAL is the cause, but I suspect the Winbond W27C512 ROM more as it's the next slowest device and at 45ns (22MHz) is skirting the edge. As Garth says, the speed rating doesn't include set up times, etc., so it's very possible that this is the culprit.
Like Jeff, I think it's your ROM that is the bottleneck. Most GALs are either 10 or 15ns, which is more than sufficient for 20 MHz operation.
You have to consider that a read access on the ROM can only occur during the Ø2 high part of the machine cycle. At 16 MHz, a half cycle would be approximately 31ns. If your ROM were capable only of 45ns access time it would never respond. It just so happens that most devices are able to perform better than advertised due to margins the manufacturers design in to assure their product will meet guaranteed specs when operated at rated voltage and temperature range. You might find that at 16 MHz, a nominal increase in device temperature may cause the circuit to go dead.
For example, I have my POC unit running at 12.5 MHz. This is with a 55ns EPROM. Obviously, I am violating the EPROM's timing, as the half cycle time is 40ns, and access can only occur during Ø2 high. If I increase Ø2 to 15 MHz, the unit might boot or it might not. It all depends on which EPROM I happen to be using at the time, as they vary from part to part, even though they are all the same brand (AMD).
You should see if you can rig up Jeff's wait-state circuit. That will definitively settle the speed issue.
PostPosted: Thu Dec 31, 2015 8:52 am
One thing: I don't currently qualify reads to the EEPROM with Ø2 and it all seems to work. Is this something that I should be doing? I thought this was only for RAM writes to stop the possibility of rubbish being written.
With regard to Jeff's wait state circuit: I think I might give this a go, but with an added extra: As part of the initialisation routine it would copy itself to the same location in RAM, then switch itself out. So at this point the system can go at full speed with the GAL not allowing writes to that part of the RAM there-after.
PostPosted: Thu Dec 31, 2015 9:16 am
With the '02, you'll be fine. It's just that with the '816, you need to make sure you take measures to avoid bus contention, as the '816 puts the address high byte out on the data bus during the phase-2-low time, so you wouldn't want the EEPROM to also be putting data out in a way that could make the '816 and the EEPROM fight each other.
PostPosted: Thu Dec 31, 2015 3:15 pm
That is an acceptable procedure with ROM, as long as setup and hold times on the data pins aren't violated. As Garth noted, you can't do that with the 65C816 unless you take steps to prevent bus contention during Ø2 low. That means either qualifying all reads with Ø2 or inserting a bus transceiver between the MPU and the rest of the data bus.
It's also a requirement for non-65xx I/O hardware.
It's important to understand that the data bus is not guaranteed to contain valid content until Ø2 goes high. If you write-enable RAM or I/O while Ø2 is still low the target device will see a data bus that is in a state of flux. Depending on the device, setup and/or hold times on the data inputs may be violated and produce obdurate problems.
You might be able integrate the wait-state circuit into the GAL if there are enough logic resources and pins.
PostPosted: Thu Dec 31, 2015 6:29 pm
Hi guys. Qualifying the RAM write-enable input with Ø2 confines any rubbish to the intended location (the one being addressed). IOW it protects all the other locations from being altered.
No; it's important to understand that the address bus is not guaranteed to contain valid content until Ø2 goes high.
The target device will see a data bus that is in a state of flux regardless, even if the write is qualified by Ø2 high -- check the timing diagram. At the rise of Ø2 the address bus is valid but the data bus contains garbage. It won't resolve until tMDS later (iow about 30 ns later, which is almost all of Ø2 if you're running a fast clock).
The reason it's necessary to qualify write-enable with Ø2 has to do with ensuring the address is valid -- not the data. In a proper, Ø2-qualified system here is the sequence of events for a write cycle:
  • Ø2 low: address becomes valid by the end of this period. There's no valid write data yet.
  • early in Ø2 high: still no valid write data, but the write has begun. Garbage may be written to the mem/IO device but, crucially, the write occurs strictly to the addressed location, and not any other location.
  • later in Ø2 high (after tMDS has elapsed), the data bus becomes valid. Write-enable is still asserted, which means the write continues. The just-arrived valid data will over-write any garbage written an instant before.
IOW, invalid data gets written and then replaced with something sensible -- that's just business as usual, for 65xx !! RAM only remembers the last data written, so there's no issue with RAM. And 65xx peripherals have an extra latch provided internally in cases where glitchy output would be a problem.
Qualifying the RAM write-enable input with Ø2 ensures that a write will do its muddling about :) with the intended location only, and leave other locations untouched.
PostPosted: Thu Dec 31, 2015 9:33 pm
Sorry, I have to disagree with that statement, at least in the case of the 65C816.
The timing diagram unambiguously shows that RWB, MLB, VPB, A0-A15, VDA and VPA are valid and stable prior to the rise of Ø2, specifically, no more than tADS nanoseconds after the previous fall of Ø2. The bank bits (D0-D7) are valid and stable no more than tBAS nanoseconds after the previous fall of Ø2. All this tells me that a valid address is available prior to the rise of Ø2. My design of both POC units, and the timing analysis that went into it, is based on what the timing diagram says. Both units work and are stable, so I can't be too far off the road with this.
Which brings up the subject of data sheet accuracy. According to WDC, tBAS is a maximum of 33ns at 14 MHz, whereas tADS is quoted as 30ns at 14 MHz. One of those numbers is incorrect, since they suggest that VDA and/or VPA go high before the bank bits are valid. That seems to me to be not right, seeing as how VDA and VPA are there to tell the glue logic when a valid address is present.
PostPosted: Thu Dec 31, 2015 9:53 pm
The important point is that the address bus can present invalid addresses before tADS, on its way to forming the right address. You definitely do not want to be writing to those invalid addresses. Write data is not guaranteed to be valid and stable until tMDS after the rise of phase 2. The data sheet definitely has some puzzlers though. I wrote to Mensch 15 years ago or so about one of the timing conflicts in the data sheet, and he wrote back saying he did not have an answer for it. Fortunately, as far as I can remember, the actual microprocessors have always done better than the data sheet specifies.
PostPosted: Thu Dec 31, 2015 9:54 pm
I'm sure we've been through this before...
PostPosted: Fri Jan 01, 2016 8:28 am
The problem is that 'tADS nanoseconds after the fall of Ø2' is hard to express in hardware, whereas 'when Ø2 is high' is easy to express.
PostPosted: Fri Jan 01, 2016 5:46 pm
No argument on that. Unfortunately, WDC based the address setup timing on the (previous) fall of the clock. When I first decided to build my POC unit, I was struggling to get my head wrapped around this. It seemed more logical to quote timing on what was about to happen with Ø2, rather than what had already happened.
PostPosted: Fri Jan 01, 2016 6:02 pm
That's because they describe what the hardware does. The outputs are probably registered on the falling clock, and tADS is the delay of the output flipflops plus the pad to pin delay. On the other hand, there's no relationship to the next edge, so they can't specify that.
PostPosted: Fri Jan 01, 2016 6:05 pm
Convenient though it may be BDD, it's not logical, as it can lead to the misconception that the rising edge of the clock is a useful timing reference. (Note that the original conversation was about the 6502 - bringing the 816 into the equation muddies the waters yet further.)
PostPosted: Fri Jan 01, 2016 6:27 pm
Not entirely. If you remove the 65C816-specific outputs from the discussion you are looking at essentially the same timing model as that of the 65C02.
PostPosted: Sat Jan 02, 2016 8:34 am
Hmm -- I was flummoxed by this remark, but now I realize that imperfectly precise wording on my part opened the door to something other than the point I was driving at.
Right. I've marked up part of the '02 timing diagram (below) to illustrate. When the valid address appears at Point A, it's the result of the fall of Ø2 which occurred previously. IOW the valid address doesn't appear "in anticipation" of Point B in future when Ø2 is expected to rise. Hardware can't anticipate something that hasn't happened yet. I could clarify my quote at the top of this post as follows. "The address bus will already contain valid content by the time Ø2 goes high because presumably the clock source keeps tPWL within spec, and even at its minimum, tPWL will be longer than the maximum tADS delay produced by the CPU."
Returning to the actual, original cause of my quibble, I believe Banedon was asking why we qualify RAM write-enable with Ø2. As I explained in my post Thursday, the answer is...
If you write-enable RAM or I/O while Ø2 is still low the target device will see an address bus that is in a state of flux -- not
However, the following is correct:
When running near maximum speed, '02 systems and '816 systems both take almost all of the Ø2-low time to produce a valid address; prior to that the address is garbage. And for write cycles they take almost all of the Ø2-high time to produce valid write data; prior to that the write data is garbage -- and that's normal; static RAM and 65xx peripherals can tolerate that, even though write-enable is asserted throughout the period of flux.
PostPosted: Sat Jan 02, 2016 9:07 am
...and for non-65xx peripherals we have flops to generate wait-states. :D
Users browsing this forum: No registered users and 41 guests
