It is currently Sat Nov 16, 2024 8:50 pm
PostPosted: Mon Nov 30, 2015 1:21 pm
How does one deal with the different register sizes in a 65816 disassembler? So far all I can think of is to try to keep track of SEP/REP instructions.
PostPosted: Mon Nov 30, 2015 1:51 pm
There isn't going to be a foolproof way - that's the nature of mode bits. So whatever you do by way of guessing, be sure to allow an override.
PostPosted: Mon Nov 30, 2015 3:55 pm
That's how I do it in Supermon 816.
PostPosted: Tue Dec 01, 2015 10:22 am
Yeah, this is a problem. For the Forth disassembler, I have these routines:
\ handle register size switch and add comment
: .sep  ( addr+1 -- addr+1)
   dup c@
   case  .commentspace
      10 of xy:8  ." xy:8" endof
      20 of a:8  ." a:8" endof
      30 of a:8 xy:8  ." axy:8" endof
      ." warning: unusual use of sep" endcase ;
 \ print comment for rep register size switch
: .rep  ( addr+1 -- addr+1)
   dup c@
   case  .commentspace
      10 of xy:16  ." xy:16" endof
      20 of a:16  ." a:16" endof
      30 of a:16 xy:16  ." axy:16" endof
      ." warning: unusual use of rep" endcase ;
In other words, we check the byte after REP and SEP and set internal flags depending (xy:8, a:16, etc). To help with debugging, the disassembler adds a comment to the output so the user knows what the program thinks it knows. If REP or SEP are not used for normal register switches, print a warning.
PostPosted: Wed Dec 02, 2015 4:29 pm
Thanks. I feel that some (if unreliable) detection strategies are needed. The register size detection seems pretty straightforward, but trying to detect the emulation mode could have problems:
; the usual way
clc
xce
; an unusual way which relies on some result
adc #29
xce
This seems unlikely though?
PostPosted: Wed Dec 02, 2015 5:03 pm
Yes, that's unlikely!
PostPosted: Thu Dec 03, 2015 3:22 am
; the usual way
clc
xce
adc #29
xce
More like pointless. Why use three bytes to do a two-byte job?
It's a rare case where switching between native and emulation modes occurs as a regular activity. About the only one I can think of off-hand is when a eight bit Apple is retrofitted with an '816.
PostPosted: Thu Dec 03, 2015 3:51 am
... More like pointless. Why use three bytes to do a two-byte job?
I don't know of any way to increase the accumulator by 29 or 30 and potentially switch modes in only two bytes of code, so I personally would be more inclined to call it "obscure" or maybe "obtuse", rather than "pointless". Some other "ob-" words also come to mind, like "obfuscated" and "obnoxious".
I installed a 65c802 in my old Apple ][+ back in about 1990, to experiment with the 16-bit registers. It was fun for awhile, but a bit cumbersome, because the monitor was completely clueless about what I was trying to do. I thought about adding the necessary monitor functionality myself, but eventually moved on to a different interest instead. I grew weary of all the mode-switching, which couldn't be avoided to get my experiments to "play nice" with the Apple ][ firmware. I went through my attic recently, but only found a //e and a Franklin Ace up there ... I hope I didn't lose that '802 in one of my moves. Meh ... easy come, easy go ...
Mike B.
PostPosted: Sun Dec 20, 2015 9:01 pm
I came across an article in Apple Assembly Lines archive on just this topic: http://txbobsc.com/aal/1986/aal8603.html#a4
I also have a 65802 installed in a Laser 128EX that I just got working today after being in storage and moving again and again and again...
Regards,
Andy
Users browsing this forum: Google [Bot] and 7 guests
cron
