what is a good parts list for a beginner to buy at mouser
- GARTHWILSON
- Forum Moderator
Re: what is a good parts list for a beginner to buy at mouse
The dead bus cycles are predictable. In the data sheet (you might have to look at the '816 data sheet to get the info on what happens in every cycle of every addressing mode), it shows dead bus cycles as "IO" for "internal operation." In the case of reset, the 65c02 reset process that it carries out after the RST\ line comes up takes 7 clocks, and it fetches the reset vector in numbers 6 and 7.
beholder wrote:
Hi Banedon.
I figured out why it wasn't working on 115200, the serial window has a dropdown option box where you choose which rate.
Didn't know I had to set the arduino project and the serial window
Sounds like you're doing well with your project. As Garth says; That boot sequence sounds normal.
I've just booted up my latest creation and it gave:
Address bus Data bus Notes
$FFFF $EF
$FA43 $00
$01FF $5F access the stack/stack initialisation
$01FE $AF access the stack/stack initialisation
$01FD $FD access the stack/stack initialisation
$FFFC $00 load LSB of reset vector
$FFFD $F0 load MSB of reset vector
$F000 jump to reset vector & start of my main code at $F000Re: what is a good parts list for a beginner to buy at mouse
banedon wrote:
I find out things this way all the time with electronics
$FFFF $EF
$FA43 $00
$FFFF $EF
$FA43 $00
