cbscpe wrote:
The synchronous design would require that everything happens synchronously to PHI2. The easiest is to have the AVR create PHI2 and poll a "chip-select" and read some address bits to know when to read or write to the 6502 like in
Michael's 3-chip design.
That is how I do it in my 3-chip design with the extra advantage that the PIC microprocessor performs the address decoding and doesn't have to poll for its chip select signal.
But this is limited to rather low PHI2 clock rates, even if the AVR just copies from the 6502 to the internal registers this uses at least 10-20 cycles.
That's correct. My PIC, with 62.5-nS instruction cycles (like a 16-MHz AVR), uses exactly 16 instruction cycles per 65C02 clock cycle to perform its functions, which limits the 65C02 clock to 1-MHz. If I upgrade to a PIC24 device I could have a 4-MHz 65C02 clock.
... only using the USART of the AVR it is not worth the effort as BDD mentions correctly...
I agree. I can only justify using the PIC in my 3-chip design because it provides "direct" full-speed (1-MHz) access to the PICs Serial and
high-performance SPI peripheral registers as well as providing the CPU clock and reset signals, a blind loader function, and 'soft' address decoder function. For ROMless designs with 'classic I/O' like an ACIA and/or VIA that don't require PIC peripheral access, I use a 28-pin PIC strictly for Reset, Clock, Loader, and Decoder functions.
