It is currently Sun Nov 17, 2024 6:00 am
PostPosted: Wed May 04, 2005 9:03 pm
So if I read through the forum, it's clear that the 65816's top 8 address bits (the multiplexed ones) are a nasty quirk.
The version on the datasheet with the latch, inverter, and buffer, gives out at some point. After that, you really need a silicon delay line or other nasty things that has never been described in good enough detail.
Has anybody ever done enough experimentation to give a proper rule of thumb for how fast one can run the 816 before this is a problem? Does the type and speed of the latch, inverter, and buffer make any difference?
PostPosted: Wed May 04, 2005 10:00 pm
I have not, nor have I heard from anyone else doing such.
PostPosted: Wed May 25, 2005 12:39 am
The faster the clock, the less of a problem the silicon delay lines become -- you require fewer and fewer gates to achieve it.
The answer to this question is elusive because technology is always changing. With a suitably sized PAL chip, or an FPGA, one can decode the bank address byte in real-time, especially if the CPU and the decoder chips are physically adjacent on the motherboard (as they should be anyway).
PostPosted: Wed May 25, 2005 6:58 am
For my opinion the combination (VPA OR VDA) NAND PHI2 should give the correct timing to latch the upper byte. The part in brackets results in a "valid address" signal, which implies "valid bank address".
Another problem is the need to meet the address hold time after the PHI2 phase. At about 14 MHz I got spikes on the upper address lines, if I used only the end of the PHI2 phase as a criteria for the latching, because the cpu data was still on the bus.
PostPosted: Thu May 26, 2005 3:27 pm
Wouldn't you need to also take RDY into consideration as well? For example, if RDY goes low, then the data bus will likely have *data* on it during ph2 low. Or, does the CPU force the data bus with the bank address byte even then?
I will need to re-study the timing diagrams, or maybe set up an experiment somehow.
PostPosted: Sun May 29, 2005 11:38 am
You are right. That might be a problem. As I normally don't use the RDY signal, I have no experience with its behaviour. In the the data sheet I haven't found an answer.
