It is currently Sun Sep 22, 2024 4:28 pm
Post new topic Reply to topic  [ 60 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: New 65C02 project
PostPosted: Thu Sep 03, 2015 11:01 pm
Aslak3 wrote:
A trivial point, but I believe the cap on the MAX238 on the V+ pin is backwards.
Well spotted! I didn't see that earlier.
PostPosted: Fri Sep 04, 2015 3:50 am
That's why I use ceramics :)
PostPosted: Fri Sep 04, 2015 7:59 am
Now that I've had a chance at having a proper sit down and think: I qualified the CS for the RAM with PHI2, not read/write signal. Is this incorrect?
PostPosted: Fri Sep 04, 2015 8:24 am
If you're nearing the speed limit of the RAM, having the RAM's CS\ qualified by phase 2 is not ideal. (It's fine at lower speeds though.) What BDD was saying to qualify with phase 2 was the RAM's WR\. The idea of the logic for that and the OE\ is shown in the last diagram of the clock generation page of the 6502 primer.
PostPosted: Fri Sep 04, 2015 2:38 pm
You should not qualify any chip selects with Ø2. Where Ø2 qualification should be applied is in generating your /RD and /WR signals. In CUPL, the logic is written as /RD = RWB & PHI2 for fetches, and /WR = !RWB & PHI2 for stores, where & is logical AND and ! is logical NOT.
The preceding does not apply to 65xx I/O devices, which should be directly driven by the MPU's RWB output.
PostPosted: Fri Sep 04, 2015 3:04 pm
Okey dokey. I'll re-do the GAL code this evening and rewire the RAM R/W pin. Cheers.
[edit] Here's an updated schematic:
GAL 1 - Main Decoder (IC 2)
Name       AddressDecoder1;
Partno     Lattice22V10B;
Date       11/07/15;
Revision   01;
Designer   shalewyn.com;
Company    shalewyn.com;
Assembly   1;
Location   1;
Device     g22v10;
 * Lattice GAL 22V10B pinout, DIP, top view
 * I/CLK.[ 1     24 ].VCC
 *     I.[ 2     23 ].I/O/Q
 *     I.[ 3     22 ].I/O/Q
 *     I.[ 4     21 ].I/O/Q
 *     I.[ 5     20 ].I/O/Q
 *     I.[ 6     19 ].I/O/Q
 *     I [ 7     18 ].I/O/Q
 *     I [ 8     17 ].I/O/Q
 *     I [ 9     16 ].I/O/Q
 *     I [ 10    15 ].I/O/Q
 *     I [ 11    14 ].I/O/Q
 *   GND.[ 12    13 ].I
 * Inputs
Pin 1 = phi2;
Pin 2 = cpuRW;
Pin [3..10] = [A7..0];
 * Outputs
Pin [16..21] = ![S0..5];
Pin 22 = aRD;
Pin 23 = aWR;
aRD = !cpuRW;
aWR = cpuRW;
Pin [16] = s[0];   nROM select;
Pin [17] = s[1];   nRAM select;
Pin [18] = s[2];   nLatch1 select;
Pin [19] = s[3];   nVIA #1
Pin [20] = s[4];   nVIA #2
Pin [21] = s[5];   nACIA
Pin [22] = aWR;
Pin [23] = aRD;
 * Main
FIELD AddressBus = [A7..0];
FIELD Selects = [S5..0];
TABLE AddressBus => Selects {
   [00..1F] => 'b'000010 & cpuRW;       /* Non-swap RAM read */
   [00..1F] => 'b'000010 & !cpuRW;    /* Non-swap RAM write */
   [20..7F] => 'b'000010 & cpuRW;       /* Swap RAM read */
   [20..7F] => 'b'000010 & !cpuRW;    /* Swap RAM write */
   [81..81] => 'b'001000 & cpuRW;       /* VIA #1 read */
   [81..81] => 'b'001000 & !cpuRW;       /* VIA #1 write */
   [82..82] => 'b'010000 & cpuRW;       /* VIA #2 read */
   [82..82] => 'b'010000 & !cpuRW;       /* VIA #2 write */
   [83..83] => 'b'100000 & cpuRW;       /* ACIA read */
   [83..83] => 'b'100000 & !cpuRW;       /* ACIA write */
   [84..84] => 'b'000100 & cpuRW;       /* Latch read */
   [84..84] => 'b'000100 & !cpuRW;       /* Latch write */
   [90..FF] => 'b'000001 & cpuRW;       /* ROM read*/
GAL 2 - Secondary Decoder (IC 3)
Name       AddressDecoder2;
Date       11/07/15;
Revision   01;
Assembly   1;
Location   1;
Device     g22v10;
 *     I.[ 2     23 ].I/O/Q
 *     I.[ 3     22 ].I/O/Q
 *     I.[ 4     21 ].I/O/Q
 *     I.[ 5     20 ].I/O/Q
 *     I.[ 6     19 ].I/O/Q
 *     I [ 7     18 ].I/O/Q
 *     I [ 8     17 ].I/O/Q
 *     I [ 9     16 ].I/O/Q
 *     I [ 10    15 ].I/O/Q
 *     I [ 11    14 ].I/O/Q
 *   GND.[ 12    13 ].I
 * Inputs
Pin 1 = phi2;
Pin 2 = cpuRW;
Pin [3..6] = [A15..12];
Pin 7 = !IRQin1n;
Pin 8 = !IRQin2n;
Pin 9 = !IRQin3n;
Pin 22 = !IRQin_od;
Pin 10 = sbr0n;
Pin 11 = sbr1n;
Pin 13 = sbw0n;
Pin 14 = sbw1n;
 * Outputs
Pin 16 = sramA15n;
Pin 17 = sramA16n;
Pin 23 = !IRQout;
 * Main
/* IRQ set up */
IRQout = IRQin1n # IRQin2n # IRQin3n # IRQin_od;
   R/W   SBR0 SBR1 SBW0 SBW1 A15 A16
   1   0    0    0    0    0   0
   1   0    1    0    0    1   0
   1   1    0    0    0    0   1
   1   1    1    0    0    1   1
   0   0    0    0    0    0   0
   0   0    1    0    0    1   0
   0   1    0    0    0    0   1
   0   1    1    0    0    1   1
FIELD BankCtrl = [cpuRW, sbr0n, sbr1n, sbw0n, sbw1n];
FIELD BankOut = [sramA15n, sramA16n];
FIELD AddressBus = [A15..12];
TABLE BankCtrl => BankOut {
   'b'100xx => 'b'00;
   'b'101xx => 'b'10;
   'b'110xx => 'b'01;
   'b'111xx => 'b'11;
   'b'0xx00 => 'b'00;
   'b'0xx01 => 'b'10;
   'b'0xx10 => 'b'01;
   'b'0xx11 => 'b'11;
PostPosted: Sat Sep 05, 2015 4:19 pm
Having some issues trying to qualify the A15 and A16 output so that it only gives 0 on each when an address of $0000-$1FFF comes up.
This doesn't work, so will need have a think:
FIELD Addr = [A15..12];
FIELD BankCtrl = [cpuRW, Addr, sbr0n, sbr1n, sbw0n, sbw1n];
   /* $0000-$1FFF detect */
   'b'x000xxxxx => 'b'00;
   'b'10xxx00xx => 'b'00;
   'b'10xxx01xx => 'b'10;
   'b'10xxx10xx => 'b'01;
   'b'10xxx11xx => 'b'11;
   'b'00xxxxx00 => 'b'00;
   'b'00xxxxx01 => 'b'10;
   'b'00xxxxx10 => 'b'01;
   'b'00xxxxx11 => 'b'11;
PostPosted: Sat Sep 05, 2015 5:26 pm
Hi banedon,
here some input to your design files.
Table is not well suited for your purpose, you should really use equations for that case. Also you need to be very careful when using variables with subscripts, like A12, A13, A14, A15 etc. WinCUPL now allocates a 32-bit chunk and places the bits according to the subsript. This said you should change your code.
FIELD Address = [A15..0];
sramA15n = Address:[0000..1FFF] & RW & !sbr0n & !sbr1n
# Address:[0000..1FFF]
if the address ranges you use do not require the address lines A0 to A11 WinCUPL will accept that there are no pins for these signals. Also your code gets much more readable as you now use the "real" addresses in the square backtes as they are seen by the CPU.
Then in your first post with in the first GAL the read and write signals must be qualified with PHI2
aRD = phi2 & !cpuRW;
aWR = phi2 & cpuRW;
you have no registered outputs (no flip flops used) so pin 1 is used as input and not as clock and you can use phi2 as normal input signal. As already said in a former response, pin 1 is only activated as clock input if you have registered outputs. And you should use the FIELD statement with the full 16-bit address, it makes your code clearer.
Peter
PostPosted: Sat Sep 05, 2015 5:28 pm
Ok we have a possible winner:
TABLE Addr => BankOut {
   [0..1FFF] => 'b'00;
   [2000..7FFF] => 'b'00 & cpuRW & !sbr0n & !sbr1n;
   [2000..7FFF]  => 'b'10 & cpuRW & !sbr0n & sbr1n;
   [2000..7FFF] => 'b'01 & cpuRW &  sbr0n & !sbr1n;
   [2000..7FFF] => 'b'11 & cpuRW &  sbr0n &  sbr1n;
   [2000..7FFF] => 'b'00 & !cpuRW & !sbw0n & !sbw1n;
   [2000..7FFF] => 'b'10 & !cpuRW & !sbw0n &  sbw1n;
   [2000..7FFF] => 'b'01 & !cpuRW &  sbw0n & !sbw1n;
   [2000..7FFF] => 'b'11 & !cpuRW &  sbw0n &  sbw1n;
Am testing and tuning atm. Looking good, though
PostPosted: Sat Sep 05, 2015 5:36 pm
cbscpe wrote:
Hi banedon,
aWR = phi2 & cpuRW;
Peter
Hi Peter
Thanks for your advice.
Given that TABLE is one of those commands that makes me want to uninstall WinCUPL, I was on the edge of doing as you're suggesting and splitting it all down, but I think I've now cracked it. I do notice that my solution and your are pretty much the same, except I'm using a TABLE.
The phi2 is there from before but you're right: I don't need it in the second GAL. I'll keep it there as I don't need the pin, but will get rid of it in the schematic and will ditch it if I need to re-purpose pin 1. I know (from you previous advice :)) that I do not need to have that as PHI2.
PostPosted: Sat Sep 05, 2015 6:20 pm
Ok that works. I now have the following parts of the memory map working (I've reduced the base RAM in favour of expanding the RAM banks):
$0000-$0FFF = non-swap/base RAM
$1000-$7FFF = RAM banks 0, 1, 2 and 3 selectable via Latch #1
$8400-$840F = Latch #1. Lines 0-1 used to select the active RAM bank for read operations, lines 2-3 for write operations
$9000-$FFFF = OS EEPROM
H/W-wise, I still need to implement:
Fully connecting VIA#1, VIA#2 and the ACIA (+line drivers)
IRQ support for all of the above
The above gives access to 116KB of RAM in total (28KB per bank (4) + 4KB for the base), 28KB for ROM and 4KB for memory mapped I/O devices
PostPosted: Sun Sep 06, 2015 5:28 am
You have a 10K pull-up resistor on the IRQ line going to the UART. I recommend you reduce it to 3.3K. Otherwise, you may run into spurious interrupt problems.
PostPosted: Sun Sep 06, 2015 7:54 am
I know that if the resistance of a pull up resister is too high then it can slow reaction times of state changes within a connected IC pin. Is this what you're referring too?
PostPosted: Sun Sep 06, 2015 8:42 am
Good to see your project is making progress.
Yes exactly, that's the way to do it with tables. When starting with CPLDS (ATF15xx) I also often used tables, but I abandoned them, as I think the method using ADDRESS:[from..to] is often more readable and easier to maintain. There are of course times when tables are very useful, like in the thread which discussed the use of a GAL instead of a small ROM to boot a system http://forum.6502.org/viewtopic.php?f=10&t=3383
As for the pull-ups for IRQ et.al. I normally use 2k2 or even 1k8. Faster is always better and as these signals are high for 99% of the time some mA more or less don't matter, especially considering that a fast GAL alone uses 100mA and more.
PostPosted: Sun Sep 06, 2015 9:27 am
Thank you :)
I'll have a play around with the ADDRESS command to see if it suites me better.
With regard to your suggestion regarding 2k2 or 1k8 - We're taking about 2.2mA for 2k2 and 2.7mA for 1k8? If so, then I tend to agree. Apart from the power usage are there any downsides of doing this?
