It is currently Sun Nov 17, 2024 5:42 am
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
Which do you choose?
EPROM 11%  11%  [ 1 ]
EEPROM 89%  89%  [ 8 ]
Total votes : 9
 Post subject: Re: EPROM or EEPROM?
PostPosted: Fri Aug 28, 2015 11:48 am
nkeck72 wrote:
About the NVRAM and FRAM... to protect from malicious users (just to be safe) is there usually a write protect feature?
Edit: being the bonehead I can be sometimes, write protect comes in handy, especially when I mean to program $E000 (I/O) and actually type $F000 (ROM)
With NVRAM you can simply tie the R/W pin to +5V using a 3K3 resistor. Or (if you want to be able to write, but protect the contents against accidental erasure) you could possibly tie the R/W pin to, say, a latch or even a VIA pin (probably best to also have a 10K pull up resistor to deal with tri state before the VIA is programmed).
Something like this:
The only thing I'm not sure of is the need for the pullup resistor on the VIA_PIN line (R1). I've put it in so that you hopefully the NVRAM write pin will never enable writing (logic 0) spuriously (during boot/reset, VIA setup, etc.). As I say, it might not be needed, but its inclusion shouldn't cause any problems and it's best to be safe :mrgreen:. The use of HC or AC logic is recommended for the OR gate IC as you don't want to ahve to wait CPU cycles for the state of the VIA_PIN to affect the WE pin of the NVRAM when you decide to change it. Also, having the OR gate introduces a propogation delay which can possibly affect the maximum speed of your design. Fast=Good.
PostPosted: Fri Aug 28, 2015 9:46 pm
You could also add a hardware switch, operated manually, like the gizmo on floppy discs or SD cards.
PostPosted: Tue Sep 01, 2015 3:34 pm
Yes, I think you have to look after write-protect in your own circuit - the chips don't do it for you. You might for example want to write protect only the top part of the chip, containing the vectors and boot code.
cron
