It is currently Thu Nov 14, 2024 6:37 am
 Post subject: 65xx clock pulse type?
PostPosted: Tue Mar 18, 2003 12:24 am
I am working on my first mircp project and was wondering, for mirco p's can I use a good clean squarewave 1:1 ratio instead of worrying about a pulse waveform.
thankyou!
NPastoll
PostPosted: Wed Mar 19, 2003 4:22 am
thankyou!
At slow speeds (around 4MHz or so), it really doesn't matter what you use for a clock. But, as the speed increases, you really want to get a nice, clean 50% duty cycle for your clock. Otherwise, you run the risk of violating setup and hold times for the CPU and for memory devices.
Another advantage of using a 50% duty cycle is that you can multiplex the bus with another bus master without having to worry about DMA support hardware.
Samuel A. Falvo II
Users browsing this forum: No registered users and 31 guests
