It is currently Sun Sep 22, 2024 8:47 am
PostPosted: Sat Aug 22, 2015 5:31 pm
I recently added a 65816 assembler module for naken_asm (and rewrote the 65xx assembler from scratch). Besides $, older syntax still doesn't work, but I plan to support as much as I can. Where might I learn what the de-facto assembler standards are for both chips?
PostPosted: Sat Aug 22, 2015 8:58 pm
I can't pass up the opportunity to recommend the excellent programming manual available for free download, "Programming the 65816 including the 6502, 65C02, and 65802" by David Eyes and Ron Liechty. It has the standard syntaxes. This is a .pdf file of a rather large book that is well laid out and is much better than the description there lets on. Note: There were many problems with the earlier .pdf version that were not in the original paper manual; but in late March 2015, WDC scanned and OCR'ed the paper manual and posted the new, repaired .pdf.
PostPosted: Mon Aug 24, 2015 9:49 pm
The book recommendation helped a lot, thank you. So far '<', '>', and '!' works. '$' already worked, but we still have to add '%' and '&', as well as directives for accumulator/index sizes on the 65816 (longa on/off, etc).
I've noticed that some listings have "LDA A" or "ROL A" etc, so I may add that also, although it seems redundant. Anything else I'm missing?
PostPosted: Mon Aug 24, 2015 10:08 pm
In the C32 assembler I use, #< can be used to force 8-bit immediate addressing; so for example if you want an LDY #4 but the index registers are to be in 8-bit mode, you'd do LDY #<4. Then you don't have to use extra lines to tell the assembler whether to assemble 8-bit or 16-bit operands. It works very well, and I have come to prefer it.
As for things like ROL A, I like it to accept it without the A to make the source code a little cleaner. If there's no operand specified on these, then it's automatically A.
PostPosted: Mon Aug 24, 2015 11:46 pm
This seems a lot clearer to me, and already works. I realized that its possible to use 'A' for a label name so I don't think I can support it anyway. Thanks.
PostPosted: Tue Aug 25, 2015 5:54 am
The MOS Technology standard assembler syntax required that all accumulator instructions other than implied have an operand. I no longer recall the exact reason why, but ROL A in that standard means left-rotate the accumulator, with A symbolically representing the accumulator. An instruction such as LDX #A would cause a syntax error, as A is a reserved symbol. I also recall that something like A = 10 would cause an error, again because A was reserved.
The supported radices in that standard are % for binary, @ for octal, none for decimal and $ for hexadecimal. I believe those were "borrowed" from the Motorola 6800 assembly language for both political and practical reasons. The official MC68000 assembly language uses them as well.
The assembly language syntax described in the 65C816 data sheet largely continues the MOS Technology standard, with additional operators to accommodate 24 bit addressing and cases where one or two bytes of a 24 bit operand are needed. It's generally good practice to stick to publish standards and avoid the temptation to devise alternatives.
PostPosted: Fri Aug 28, 2015 4:13 pm
I think I can actually support everything mentioned, so hopefully this time around the full syntax will work for 65xx/65816.
Since this is part of a larger assembler suite, the default modern syntax is also available:
https://github.com/mikeakohn/naken_asm/ ... ter/README
I added .b, .w, and .l suffixes which force certain addressing modes (direct-page, absolute, and absolute-long, respectively). With these additions, it's possible to use the default syntax entirely if desired.
(The choice exists but discretion should be used when using a non-standard syntax: mention it in the code, etc.)
PostPosted: Thu Sep 03, 2015 9:49 am
When coding an assembler for my forth, I found that I couldn't use A as an argument since it would prevent using A as a constant or variable. I reluctantly concluded that instructions like ROLA, LSRA were the least complicated methods of coding these accumulator mode instructions.
cron
