It is currently Sun Nov 10, 2024 11:26 am
Post new topic Reply to topic  [ 31 posts ]  Go to page 1, 2, 3  Next
PostPosted: Mon Jun 22, 2015 10:01 am
Elsewhere is a discussion about how to test that an emulator has the right instruction timings - Klaus' functional test suite isn't ideal for this although it could perhaps be a confidence test. Other representative code can also be a confidence test.
I thought it might be useful to have a test specifically for this purpose, so please see
https://github.com/BigEd/6502timing
and please let me know how you get on.
Until we find a way to run a test like this on a real 6502 and count the cycles, the best we can do is compare various emulators. In case of differences we can run subsets of the test, branch and bound until we find the first discrepancy.
Obviously, to compare we need to use the same version of the program, have no interrupts running, no stolen cycles with RDY, and account for all the instructions in the program and no more. Could be fiddly.
Assembly syntax is for Michal Kowalski's simulator as found at http://www.exifpro.com/utils.html because that was the easiest way to both assemble and get timings. Edit: but see below, the cycle count model in this simulator is not accurate.
Edit: summarised results for various models here.
Edit: attached a zipfile with source, listing, and a binary file.
Edit: updated the zipfile with changes to label syntax
Edit: here's the current version of the program in srec format - it's to be loaded and run at $1000
S1231000A2FF9AA2018617861886168AA898BAAAA200A0000117051709000D1717111715F2
S1231020171D1717191717CA880117111715171D1717191717E8C82117251729002D17170B
S1231040311735173D1717391717CA882117311735173D1717391717A200A0004117451740
S123106049004D1717511755175D1717591717CA884117511755175D1717591717A200A0F0
S1231080006117651769006D1717711775177D1717791717CA886117711775177D171779EC
S12310A01717A200A000A901811785178D1717911795179D1717991717CA88811791179516
S12310C0179D1717991717A200A000A117A517A900AD1717B117B517BD1717B91717CA8871
S12310E0A117B117B517BD1717B91717A200A000C117C517C900CD1717D117D517DD171735
S1231100D91717CA88C117D117D517DD1717D91717A200A000E117E517E900ED1717F11772
S1231120F517FD1717F91717CA88E117F117F517FD1717F91717A200061746170E17174EF7
S12311401717161756171E17175E1717CA161756171E17175E1717A200261766172E1717F7
S12311606E1717361776173E17177E1717CA361776173E17177E1717A000A6178617AE1762
S1231180178E1717B6179617BE171788B6179617BE1717A200C617E617CE1717EE1717D6BA
S12311A017F617DE1717FE1717CAD617F617DE1717FE1717A2001002105C30FE10FAF00289
S12311C0F056D0FEF0FAA2FF3002304E10FE30FAD002D048F0FED0FA1890029041B0FE9029
S12311E0FA38B002B03A90FEB0FAB85002503370FE50FAA97F697F7002702950FE70FAC805
S123120088E8CAEA0A2A4A6A202612486808287858F8D84C3B1210A6F0AC30B4D0BA90C13C
S1231220B0C850CF70D9203412AD3312A20081176C17006068186901484840A20024172C92
S12312401717A4178417AC17178C1717B4179417BC1717CAB4179417BC1717C017C417CC6A
S10F12601717E017E417EC17174C0010E8
File comment: Source, listing and binary to load at $1000
timingtest.zip [8.21 KiB]
Downloaded 244 times
PostPosted: Mon Jun 22, 2015 12:41 pm
I realised that visual6502 should be more of a gold standard. To start the program at $1000 I need to start with a jump, so the execution trace looks like this:
cycle    ab   db   rw   Fetch      pc    a    x    y    s     p
0      0000   4c   1   JMP Abs   0000   aa   00   00   fd   nv‑BdIZc
3      1000   a2   1   LDX #     1000   aa   00   00   fd   nv‑BdIZc
5      1002   9a   1   TXS       1002   aa   ff   00   fd   Nv‑BdIzc
1135   1262   e0   1   CPX #     1262   60   ff   01   ff   nv‑BdiZC
1137   1264   e4   1   CPX zp    1264   60   ff   01   ff   nv‑BdiZC
1140   1266   ec   1   CPX Abs   1266   60   ff   01   ff   Nv‑BdizC
1144   1269   4c   1   JMP Abs   1269   60   ff   01   ff   Nv‑BdizC
Which means visual6502 says this test program takes 1141 cycles, compared to Kowalski's verdict of 1130. Hmm.
Maybe the page-crossing branches are not taking the extra cycle that they should, in the Kowalski simulator.
Actually, the first discrepancy is opcode 1d (ORA Abs,X) taking 5 cycles where it should take 4, in the case of not crossing a page boundary.
Conclusion: don't trust the cycle counts from this version of the Kowalski simulator. (Or the v1.2.12 version either.)
PostPosted: Mon Jun 22, 2015 5:10 pm
Thanks for starting this thread!
How about a binary version that can be incbin'd? I can't assemble the code with anything from the C64 or the CBM prg Studio. I guess I could convert the syntax. Most of the assemblers don't support local labels, and I am not sure what the .db $bb is suppose to do, or where the end of the test actually resides.
PostPosted: Mon Jun 22, 2015 5:29 pm
OK, I converted the code to a CBM prg Studio project and I get 1141 cycles up to (but not including) the JMP $1269. I would like to recommend that you remove the local label references and make those real label names. That will open up the number of different assemblers that can assemble this code. I just changed the .1/.2 to r(plus the return number. ie. r11/r12, r21/r22, r31/r32, etc.).
PostPosted: Mon Jun 22, 2015 5:31 pm
Great - I'll attach a zip file to the head post, but it sounds like you don't need it. Your run was with a real physical C64?
Edit: oops, it seems CBM prg Studio is an IDE which includes its own emulator, so probably that's what you tested!
It seems then that these models agree:
    visual6502
    CBM prg Studio (thanks Jim)
    jsbeeb (thanks to Matt for the assist)
    T65 FPGA core (thanks Dave)
    µDrive (PIC 6502 emulator) (thanks Jim)
    VICE (thanks Jim)
This model does not agree with the above set:
    Kowalski simulator up to v1.2.12
Edit: updating the table of results.
PostPosted: Mon Jun 22, 2015 6:38 pm
It was Arthur's CBM prg Studio, see: http://www.ajordison.co.uk
I am going to move this test code to a fake ROM that I can incbin into my PIC 6502 emulator to check the cycle time as well, but I think it is going to be the same as Arthur's as I helped correct a lot of his debugger code.
PostPosted: Mon Jun 22, 2015 10:14 pm
ICE-T 65 (aka Atom Bus Monitor) to the rescue :D
Attached is the complete program single stepped (299 instructions).
The clock rate is 1MHz, so the timing are in <seconds>.<micro seconds> and are logged before the instruction executes.
It you subtract the first from the last, you get:
= 04.785946 - 04.784805
= 00.001141
= 1141 cycles
That matches Ed's Visual 6502 result.
This is with the T65 core, not a real 6502. I could repeat this with a real 6502, but we would only get the instruction addresses logged, not a live disassembly.
I'm also going to add a command to allow the cycle counter to be reset to zero.
Dave
6502 free running...
Ex Breakpoint hit at 1000
04.784805: 1000 : LDX #FF
>> s299
Stepping 299 instructions
04.784807: 1002 : TXS
04.784809: 1003 : LDX #01
04.784811: 1005 : STX 17
04.784814: 1007 : STX 18
04.784817: 1009 : STX 16
04.784820: 100B : TXA
04.784822: 100C : TAY
04.784824: 100D : TYA
04.784826: 100E : TSX
04.784828: 100F : TAX
04.784830: 1010 : LDX #00
04.784832: 1012 : LDY #00
04.784834: 1014 : ORA (17,X)
04.784840: 1016 : ORA 17
04.784843: 1018 : ORA #00
04.784845: 101A : ORA 1717
04.784849: 101D : ORA (17),Y
04.784854: 101F : ORA 17,X
04.784858: 1021 : ORA 1717,X
04.784862: 1024 : ORA 1717,Y
04.784866: 1027 : DEX
04.784868: 1028 : DEY
04.784870: 1029 : ORA (17,X)
04.784876: 102B : ORA (17),Y
04.784882: 102D : ORA 17,X
04.784886: 102F : ORA 1717,X
04.784891: 1032 : ORA 1717,Y
04.784896: 1035 : INX
04.784898: 1036 : INY
04.784900: 1037 : AND (17,X)
04.784906: 1039 : AND 17
04.784909: 103B : AND #00
04.784911: 103D : AND 1717
04.784915: 1040 : AND (17),Y
04.784920: 1042 : AND 17,X
04.784924: 1044 : AND 1717,X
04.784928: 1047 : AND 1717,Y
04.784932: 104A : DEX
04.784934: 104B : DEY
04.784936: 104C : AND (17,X)
04.784942: 104E : AND (17),Y
04.784948: 1050 : AND 17,X
04.784952: 1052 : AND 1717,X
04.784957: 1055 : AND 1717,Y
04.784962: 1058 : LDX #00
04.784964: 105A : LDY #00
04.784966: 105C : EOR (17,X)
04.784972: 105E : EOR 17
04.784975: 1060 : EOR #00
04.784977: 1062 : EOR 1717
04.784981: 1065 : EOR (17),Y
04.784986: 1067 : EOR 17,X
04.784990: 1069 : EOR 1717,X
04.784994: 106C : EOR 1717,Y
04.784998: 106F : DEX
04.785000: 1070 : DEY
04.785002: 1071 : EOR (17,X)
04.785008: 1073 : EOR (17),Y
04.785014: 1075 : EOR 17,X
04.785018: 1077 : EOR 1717,X
04.785023: 107A : EOR 1717,Y
04.785028: 107D : LDX #00
04.785030: 107F : LDY #00
04.785032: 1081 : ADC (17,X)
04.785038: 1083 : ADC 17
04.785041: 1085 : ADC #00
04.785043: 1087 : ADC 1717
04.785047: 108A : ADC (17),Y
04.785052: 108C : ADC 17,X
04.785056: 108E : ADC 1717,X
04.785060: 1091 : ADC 1717,Y
04.785064: 1094 : DEX
04.785066: 1095 : DEY
04.785068: 1096 : ADC (17,X)
04.785074: 1098 : ADC (17),Y
04.785080: 109A : ADC 17,X
04.785084: 109C : ADC 1717,X
04.785089: 109F : ADC 1717,Y
04.785094: 10A2 : LDX #00
04.785096: 10A4 : LDY #00
04.785098: 10A6 : LDA #01
04.785100: 10A8 : STA (17,X)
04.785106: 10AA : STA 17
04.785109: 10AC : STA 1717
04.785113: 10AF : STA (17),Y
04.785119: 10B1 : STA 17,X
04.785123: 10B3 : STA 1717,X
04.785128: 10B6 : STA 1717,Y
04.785133: 10B9 : DEX
04.785135: 10BA : DEY
04.785137: 10BB : STA (17,X)
04.785143: 10BD : STA (17),Y
04.785149: 10BF : STA 17,X
04.785153: 10C1 : STA 1717,X
04.785158: 10C4 : STA 1717,Y
04.785163: 10C7 : LDX #00
04.785165: 10C9 : LDY #00
04.785167: 10CB : LDA (17,X)
04.785173: 10CD : LDA 17
04.785176: 10CF : LDA #00
04.785178: 10D1 : LDA 1717
04.785182: 10D4 : LDA (17),Y
04.785187: 10D6 : LDA 17,X
04.785191: 10D8 : LDA 1717,X
04.785195: 10DB : LDA 1717,Y
04.785199: 10DE : DEX
04.785201: 10DF : DEY
04.785203: 10E0 : LDA (17,X)
04.785209: 10E2 : LDA (17),Y
04.785215: 10E4 : LDA 17,X
04.785219: 10E6 : LDA 1717,X
04.785224: 10E9 : LDA 1717,Y
04.785229: 10EC : LDX #00
04.785231: 10EE : LDY #00
04.785233: 10F0 : CMP (17,X)
04.785239: 10F2 : CMP 17
04.785242: 10F4 : CMP #00
04.785244: 10F6 : CMP 1717
04.785248: 10F9 : CMP (17),Y
04.785253: 10FB : CMP 17,X
04.785257: 10FD : CMP 1717,X
04.785261: 1100 : CMP 1717,Y
04.785265: 1103 : DEX
04.785267: 1104 : DEY
04.785269: 1105 : CMP (17,X)
04.785275: 1107 : CMP (17),Y
04.785281: 1109 : CMP 17,X
04.785285: 110B : CMP 1717,X
04.785290: 110E : CMP 1717,Y
04.785295: 1111 : LDX #00
04.785297: 1113 : LDY #00
04.785299: 1115 : SBC (17,X)
04.785305: 1117 : SBC 17
04.785308: 1119 : SBC #00
04.785310: 111B : SBC 1717
04.785314: 111E : SBC (17),Y
04.785319: 1120 : SBC 17,X
04.785323: 1122 : SBC 1717,X
04.785327: 1125 : SBC 1717,Y
04.785331: 1128 : DEX
04.785333: 1129 : DEY
04.785335: 112A : SBC (17,X)
04.785341: 112C : SBC (17),Y
04.785347: 112E : SBC 17,X
04.785351: 1130 : SBC 1717,X
04.785356: 1133 : SBC 1717,Y
04.785361: 1136 : LDX #00
04.785363: 1138 : ASL 17
04.785368: 113A : LSR 17
04.785373: 113C : ASL 1717
04.785379: 113F : LSR 1717
04.785385: 1142 : ASL 17,X
04.785391: 1144 : LSR 17,X
04.785397: 1146 : ASL 1717,X
04.785404: 1149 : LSR 1717,X
04.785411: 114C : DEX
04.785413: 114D : ASL 17,X
04.785419: 114F : LSR 17,X
04.785425: 1151 : ASL 1717,X
04.785432: 1154 : LSR 1717,X
04.785439: 1157 : LDX #00
04.785441: 1159 : ROL 17
04.785446: 115B : ROR 17
04.785451: 115D : ROL 1717
04.785457: 1160 : ROR 1717
04.785463: 1163 : ROL 17,X
04.785469: 1165 : ROR 17,X
04.785475: 1167 : ROL 1717,X
04.785482: 116A : ROR 1717,X
04.785489: 116D : DEX
04.785491: 116E : ROL 17,X
04.785497: 1170 : ROR 17,X
04.785503: 1172 : ROL 1717,X
04.785510: 1175 : ROR 1717,X
04.785517: 1178 : LDY #00
04.785519: 117A : LDX 17
04.785522: 117C : STX 17
04.785525: 117E : LDX 1717
04.785529: 1181 : STX 1717
04.785533: 1184 : LDX 17,Y
04.785537: 1186 : STX 17,Y
04.785541: 1188 : LDX 1717,Y
04.785545: 118B : DEY
04.785547: 118C : LDX 17,Y
04.785551: 118E : STX 17,Y
04.785555: 1190 : LDX 1717,Y
04.785560: 1193 : LDX #00
04.785562: 1195 : DEC 17
04.785567: 1197 : INC 17
04.785572: 1199 : DEC 1717
04.785578: 119C : INC 1717
04.785584: 119F : DEC 17,X
04.785590: 11A1 : INC 17,X
04.785596: 11A3 : DEC 1717,X
04.785603: 11A6 : INC 1717,X
04.785610: 11A9 : DEX
04.785612: 11AA : DEC 17,X
04.785618: 11AC : INC 17,X
04.785624: 11AE : DEC 1717,X
04.785631: 11B1 : INC 1717,X
04.785638: 11B4 : LDX #00
04.785640: 11B6 : BPL 11BA
04.785643: 11BA : BMI 11BA
04.785645: 11BC : BPL 11B8
04.785648: 11B8 : BPL 1216
04.785652: 1216 : BPL 11BE
04.785656: 11BE : BEQ 11C2
04.785659: 11C2 : BNE 11C2
04.785661: 11C4 : BEQ 11C0
04.785664: 11C0 : BEQ 1218
04.785668: 1218 : BEQ 11C6
04.785672: 11C6 : LDX #FF
04.785674: 11C8 : BMI 11CC
04.785677: 11CC : BPL 11CC
04.785679: 11CE : BMI 11CA
04.785682: 11CA : BMI 121A
04.785686: 121A : BMI 11D0
04.785690: 11D0 : BNE 11D4
04.785693: 11D4 : BEQ 11D4
04.785695: 11D6 : BNE 11D2
04.785698: 11D2 : BNE 121C
04.785702: 121C : BNE 11D8
04.785706: 11D8 : CLC
04.785708: 11D9 : BCC 11DD
04.785711: 11DD : BCS 11DD
04.785713: 11DF : BCC 11DB
04.785716: 11DB : BCC 121E
04.785720: 121E : BCC 11E1
04.785724: 11E1 : SEC
04.785726: 11E2 : BCS 11E6
04.785729: 11E6 : BCC 11E6
04.785731: 11E8 : BCS 11E4
04.785734: 11E4 : BCS 1220
04.785738: 1220 : BCS 11EA
04.785742: 11EA : CLV
04.785744: 11EB : BVC 11EF
04.785747: 11EF : BVS 11EF
04.785749: 11F1 : BVC 11ED
04.785752: 11ED : BVC 1222
04.785756: 1222 : BVC 11F3
04.785760: 11F3 : LDA #7F
04.785762: 11F5 : ADC #7F
04.785764: 11F7 : BVS 11FB
04.785767: 11FB : BVC 11FB
04.785769: 11FD : BVS 11F9
04.785772: 11F9 : BVS 1224
04.785776: 1224 : BVS 11FF
04.785780: 11FF : INY
04.785782: 1200 : DEY
04.785784: 1201 : INX
04.785786: 1202 : DEX
04.785788: 1203 : NOP
04.785790: 1204 : ASL A
04.785792: 1205 : ROL A
04.785794: 1206 : LSR A
04.785796: 1207 : ROR A
04.785798: 1208 : JSR 1226
04.785804: 1226 : JSR 1234
04.785810: 1234 : PLA
04.785814: 1235 : CLC
04.785816: 1236 : ADC #01
04.785818: 1238 : PHA
04.785821: 1239 : PHA
04.785824: 123A : RTI
04.785830: 1229 : LDA 1233
04.785834: 122C : LDX #00
04.785836: 122E : STA (17,X)
04.785842: 1230 : JMP (0017)
04.785847: 0101 : RTS
04.785853: 120B : PHA
04.785856: 120C : PLA
04.785860: 120D : PHP
04.785863: 120E : PLP
04.785867: 120F : SEI
04.785869: 1210 : CLI
04.785871: 1211 : SED
04.785873: 1212 : CLD
04.785875: 1213 : JMP 123B
04.785878: 123B : LDX #00
04.785880: 123D : BIT 17
04.785883: 123F : BIT 1717
04.785887: 1242 : LDY 17
04.785890: 1244 : STY 17
04.785893: 1246 : LDY 1717
04.785897: 1249 : STY 1717
04.785901: 124C : LDY 17,X
04.785905: 124E : STY 17,X
04.785909: 1250 : LDY 1717,X
04.785913: 1253 : DEX
04.785915: 1254 : LDY 17,X
04.785919: 1256 : STY 17,X
04.785923: 1258 : LDY 1717,X
04.785928: 125B : CPY #17
04.785930: 125D : CPY 17
04.785933: 125F : CPY 1717
04.785937: 1262 : CPX #17
04.785939: 1264 : CPX 17
04.785942: 1266 : CPX 1717
04.785946: 1269 : JMP FF3F
PostPosted: Mon Jun 22, 2015 11:42 pm
I get 1141 with my emulation. I created a ROM image of this code. It's a 16K image (overkill), but it contains the reset vector to jump to $C000 which is where the code is assembled to. There is no self modifying code here (yet), so there is no need move it to RAM. I have a wrapper for that if necessary.
Just incbin the ROM image and reset the CPU. The reset vector jumps to $C000. Start counting cycles from there to the 2nd NOP ($C269).
Attached is the ROM image.
File comment: 6502 instruction timing test ROM image ($C000-$FFFF). Just reset the CPU to start test.
timing_rom_C000.zip [615 Bytes]
Downloaded 251 times
PostPosted: Tue Jun 23, 2015 7:27 am
Thanks Dave - I've updated the table of results at viewtopic.php?p=38590#p38590
PostPosted: Tue Jun 23, 2015 2:41 pm
I can confirm (using the ROM I made above) that WinVICE gets 1141 cycles for the test. Just a note for those testing VICE... you need to use the "sidefx" command to turn off the surrounding hardware so just the CPU runs without interruption.
PostPosted: Tue Jun 23, 2015 2:47 pm
That's great, thanks - I've updated the summary table.
PostPosted: Tue Jun 23, 2015 2:51 pm
For testing with a real 6502 CPU I could make a wrapper that moves the code from ROM ($C000) to RAM ($0400) and jumps to the RAM, and when the test is complete it would jump back to ROM. Why? Because doing this, you could attach a LA to A15 and watch the state change high-low-high, and determine how long it took. You would have to subtract the time for the JMP instruction back to ROM.
PostPosted: Tue Jun 23, 2015 2:55 pm
It's a good idea - you can validate the timing idea by timing say 32 NOP instructions.
PostPosted: Tue Jun 23, 2015 3:35 pm
Yes, we could also do something like LDA $4000 to cause a toggle on A14 to denote the next test, and check times between these toggles for each different test. That way, if the total result was unexpected you should be able to determine exactly where the problem was.
PostPosted: Tue Jun 23, 2015 3:46 pm
Yes, finer grained timings would be a good step forward. I've been thinking, on a system with a VIA, it would be possible to read the low byte of a timer and push it to the stack, and then finally check page 1 against a known set of values. Probably needs a macro to wrap each instruction.
Another thought: to do a really thorough check of page-crossing timings, especially for branches, would be to catch all the near-miss cases, in case of an out-by-one error in an emulator. A branch instruction can even straddle a page boundary: it's important to know which value is important: the PC, or PC+1, or PC+2. An emulator could get this wrong and still pass the current test.
