cbscpe wrote:
It is indeed possible to download a design that makes use of the JTAG pins as normal IO pins. And that's it, as soon the download is finished the pins will turn into normal IO pins and never again will be usable as ISP JTAG pins, unless you have a programmer with the high-voltage programming algorithm as I suspect.
I ran this past Atmel, who verified what you said. Programming a device so that the JTAG pins become I/O pins does indeed prevent the device from being reprogrammed via JTAG. As the ATF15xx-DK3 rig programs via the JTAG pins, not via high voltage, it can't be used to "unbrick" a CPLD.
