It is currently Sun Nov 24, 2024 3:29 pm
Post new topic Reply to topic  [ 62 posts ]  Go to page Previous  1, 2, 3, 4, 5
PostPosted: Tue May 26, 2015 7:10 pm
Found some more:
http://staff.washington.edu/jon/verilog-prog.html
Which points to further works online:
http://web.archive.org/web/201303280228 ... index.html
(Via http://jon-jacky.github.io/home/links.html#engr-elec which has a great number of links to lots of interesting things.)
PostPosted: Tue May 26, 2015 11:46 pm
I was reading an earlier post and got confused. This issue has already been delt with. but here is an example of blocking assignment use.
One cannot mix blocking and non-blocking assignments to the same reg however. A simple example bitfield extract (o1, o2 and o are calculated in a blocking manner within an always block - this is synthesized code):
`BFEXT:
begin
            for (n = 0; n < DWIDTH; n = n + 1)
               o1[n] = mask[n] ? a[n] : 1'b0;
            o2 = o1 >> mb;
               o[n] = n > ml ? o2[ml] : o2[n];
         end
http://www.finitron.ca
