Consider a hypothetical 65C02 system with 128kB of RAM. To access all this RAM requires a bank switching scheme. I've been thinking about how I would do this with minimum hardware and cost. It seems that there are multiple ways to do this, each with different assumptions and potential incompatibilities with existing code.
Consider a hypothetical 6502 system with 128kB of RAM. Assume I/O addresses and are somewhere within page 0x80-0xFF. Save for the bank switching I/O, how the I/O devices are actually decoded doesn't matter, as long as A15 is set. I do not specify whether I/O devices are mirrored across each bank.
Assume bank switching is as simple as writing to an I/O location. In all cases, at least page 0xFF is mirrored across all banks- the mirrored pages must include the bank switching code, shared interrupt handler code, and the bank switch I/O device (I can imagine how to place the bank switch I/O location into page 0xFF).
Of the following, which addressing scheme/assumptions would you personally prefer?
- Each bank swaps out a full 64kB-256 bytes, including the stack and zero page.
- Each bank mirrors the stack and zero page in addition to at least page 0xFF. If absolute addressing modes to access page 0 and 1 are not used, this is the closest behavior to the '816 (how common is absolute addressing to page 0 and 1 in practice?). This can potentially break code, where code in one bank overwrites zero page variables in use by another bank.
- I/O devices are mirrored in addition to the above schemes.
- How about swapping out only page 0x02-0x7F, and treating the top 0x80 pages as ROM? Page 0x00-0x7F?
Just something to think about. In practice, what bank switching scheme have you found to be most useful, taking the above paragraph into account? Am I on the right track or off the mark?
