Michael wrote:
chessdoger wrote:
... yes in the end if you are using a ttl to USB module ..that will probably have to be inverted...
Bummer! I was hoping to avoid adding another chip.
... But as I replied before .. you could probably modify the supermon code to invert the signals.. however I think it be bit hard if you are not understanding how the whole I/o for CRT works ..I sort of looked at it at one point .. and said naghh ..best leave alone...
I was hoping you knew how to modify the SUPERMON code. No worry! I'll take a look at it.
... In a similar way I looked at using pics to control etc and be part of the old micro system ... you end up in timing issues...
I haven't experienced any timing issues or anomalies but I spent a great deal of time doing research and performing experiments to verify system and bus timing. I'm using a 64-MHz PIC (Tcy = 62.5-ns) which is approximately the same performance level as a 16-MHz AVR.
Hi
... Gals(PLD's) are almost at logic gate speed in execution(again depending on number of functions to perform ) and some of them can do it in 50ns or less.. I think you be pushing a micro controller to execute software and issue I/O signals that fast...
GALs in DIP packages are great and I would use them if it weren't for; (1) the dwindling availability of high speed parts, (2) the cost, (3) the power consumption, and (4) the lack of a good DIY programmer design.
Please don't dismiss the capabilities of the PIC in an SBC design. Could I take a moment to explain its operation, please?
Since the PIC is generating the 1-MHz clock, it knows exactly when the address lines become valid during each 65C02 clock cycle. The PIC has plenty of time to look up the chip select pattern for the page being addressed and to update the chip select outputs 187.5-nsecs before the PHI0 rising edge. In fact, the PIC only uses three instruction cycles for the "soft decoder" function out of every sixteen instruction cycles that make up each 65C02 clock cycle.
Using a PIC in an SBC design isn't for everyone. In my case, I use it to provide reset, clock, and address decoder functions and to provide "blind loader" and "blind monitor" functions (including single-step capability) that run outside of 6502 address space. The capability of the "soft decoder" is pretty remarkable, too. Uploading a new 256 byte "decoder map" file into PIC flash memory over the serial port is all that's needed to map memory and resources to recreate an Apple-I, a KIM-1, an Elector Junior, etc., or to experiment with zero page I/O.
More later. Cheerful regards, Mike
Hi Michael,
You obviously seem to have gone much further than I have wrt to pics and external control. I must admit I have not played with any fast pics .. Best I had was a 40Mhz 18f4550 chip ..and I don't think I ever ran it that fast ..mainly 20Mhz
Anyway great in what you are doing ..I'd be very much interested in any outcomes you are willing to share .... I mainly play around with pic basic pro and pics .. but I assume in what you are doing ..you might be dealing at assembly level programming ..which is not that scary ..if it is small type programs ..once it goes over a page or so ..I usually give up.. and try to look at an easier way of doing things..
I actually set out once to use an external NVram and DMA contol it between the pic and an old micro (like say a 6502) ..i,e use pic to pre load the ram/ed\it etc ..once all there.. transfer the Nvram to micro to run .. in that case you would not need super fast pic .. and could do all the control even through pic basic .. I sort of started that ..but got carried away with other stuff
Meantime I've seen people use pld's and I had to have a go with them.. they are easy to implement (could be horrable to program..but for simple stuff like cobinatorial logic ..it is easy .. once you get hang of it..
As far as price .. they are not that expensive (even compared to pics) about $5 for 22V10 24 pin chip.. has 22pins to play with..
programming them yes that can be an issue .. I ended up buying Wellon 290 programmer that can do them (about $150) .. but I believe G540 which is about half price will do them too. Best suggestion I can make about programmers and pld's ..is make sure the programmer can support it and see if someone has already used them for that chip ..since some manufacturers claim support for lot of chip .. but some of them just do not work...
All the best
mc
https://sites.google.com/site/gogleoops/
