It is currently Thu Nov 14, 2024 6:43 am
PostPosted: Thu Feb 19, 2015 11:06 am
I have this admittedly odd fascination with 16-segment LED displays -- not the normal 8-segment, mind you, which I never liked, but the stuff with the cross in the middle like in Back to the Future. Since I am redesigning my Ãœbersquirrel for the 65816 anyway, I thought I'd at least consider putting one or two of them in.
There isn't too much literature on how to drive them, but I'm guessing this is where Garth's "Using the 6522's shift register for tons of output bits" (http://wilsonminesco.com/6502primer/pot ... #22_SR_OUT) comes into play, with two 74AC595s for each LED. This adds up very quickly for more than one character, so I was wondering if it would make more sense to modify straight-shifting n times 16 bits by (say) a 74AC139 2-to-4 selector connected to two I/O port pins, which would allow selecting the character directly?
I'm not sure if this is going to be worth the effort this time around -- we're talking about a lot of hardware (including the resistors) here for what is basically a gimmick. Still, has anybody done this before, or have other suggestions? Thank you!
PostPosted: Thu Feb 19, 2015 3:53 pm
How many digits do you want? For the first computer I made (1985), I had 64 segments for the 8 characters of 7-segment-plus-decimal-point LEDs. (See http://6502.org/users/garth/projects.php?project=3 . The LEDs were yellow since Jameco had a sale on them-- $.19/ea IIRC.) I had shift registers and 64 resistors. The wiring was ridiculous. Here's the back of the board (also shown in the 6502 primer, as a reason for wire-wrap):
If I were to do it again, I would probably strobe it, with output pins (either from a VIA or from shift registers that are fed by the VIA's serial port) for the 16 segments, and one more output pin for each character's common-anode or common-cathode pin, and have interrupts timed by the VIA's T1 service it just fast enough that the flicker isn't a problem. Since the segments take turns being on and their normal duty cycle is low, the drive current when any given segment is on will need to be higher. Depending on how many characters you want and what brand of VIA you use or which logic family you use for shift registers, you might need buffers to strengthen the drive. Do make sure that there's a provision for not burning them out if there's a problem during development that stops the strobing and makes a particular set of segments turn on 100% duty cycle. One idea is to have a one-shot timer that resets the shift registers after some number of milliseconds after the last time they were strobed and have the one-shot reset every time the shift registers are strobed, such that in normal operation the one-shot never times out. If there's a problem, the one-shot resets the shift registers to save the LEDs.
PostPosted: Thu Feb 19, 2015 4:47 pm
Do the two common anodes/cathodes only control one half of the 16 segments? If so and you do want to pulse the segments, you would only need 10 pins to control it (or 9 if there is a handy way to make one anode always the complement of the other). You might end up saving some board space with less shift registers.
PostPosted: Thu Feb 19, 2015 5:22 pm
I don't know if it is still available, but the M5450 & M5451 were useful for this sort of thing. These are 40-pin chips that take a serial input and directly drive 34 or 35 segments of LED. They include built-in current limiting so there is no need for external resistors and also include a brightness control input so you can vary the display brilliance if you wish.
Shift to the left,
Shift to the right,
Mask in, Mask Out,
BYTE! BYTE! BYTE!
PostPosted: Fri Feb 20, 2015 4:22 am
I've heard these are good too but never used them: http://www.ti.com/product/tlc5940
PostPosted: Fri Feb 20, 2015 12:14 pm
Thanks people, that helped a lot -- I hadn't considered strobing at all. Also, the TI chips look good -- there is the TLC5911 (http://www.ti.com/product/tlc5911) that looks great as well. Will let you know how this turns out ...
PostPosted: Sat Mar 28, 2015 1:31 pm
FYI, once you embrace the SPI interface there is the MAX6954: The MAX6954 is a compact display driver that interfaces microprocessors to a mix of 7-segment, 14-segment, and 16-segment LED displays through an SPI- or QSPI-compatible 4-wire serial interface. See http://www.maximintegrated.com/en/produ ... X6954.html
cron
