It is currently Tue May 14, 2024 2:29 pm
PostPosted: Sat Feb 01, 2014 7:59 pm
I'm looking for an Assembler that works on 64 bit Windows. I've tried MAS65 and FASM and both are incompatible.
PostPosted: Sat Feb 01, 2014 8:24 pm
Won't it run everything that was made for 32-bit Windows and even DOS? I'm using Cross-32 (C32) from Data Sync Engineering, although I got mine back when Peter Aske was selling it under the Universal Cross Assemblers name. See http://www.datasynceng.com/c32doc.htm now. For $99 you get a macro assembler that works for dozens of different processors--they list nearly a hundred now on the referenced page--and if/when we come up with our own here, it tells how to make up the files for assembling for a new one with the same great macro assembler. The stucture-macro section of my website has the code to do the high-level structures in assembly, with C32 source code for the macros. (I have more improvements in store to make there when I get time, too.) See http://wilsonminesco.com/StructureMacros/index.html
PostPosted: Sat Feb 01, 2014 8:39 pm
Mine works on anything with Java. I use Windows 7 64-bit.
Andrew Jacobs
PostPosted: Sat Feb 01, 2014 8:50 pm
BitWise's also has the program structures, built in, ie, without needing macros to do it (although it does macros too). See http://www.obelisk.demon.co.uk/dev65/as65.html
PostPosted: Sat Feb 01, 2014 9:00 pm
Garth, I tried their binaries and got the incompatible error. If I recompiled them as Windows console apps they might work, but I figured I would just try another.
Thanks BitWise, I'll give yours a try.
PostPosted: Sun Feb 02, 2014 4:57 am
HXA runs on Win Vista 64 (as a console app).
PostPosted: Sun Feb 02, 2014 5:13 am
Doggone you guys are modest! Ok, here's Anton's HXA link: http://home.earthlink.net/~hxa/
PostPosted: Sat Dec 13, 2014 6:10 pm
I didn't see it mentioned here, but in my opinion the finest assembler available for the 65x family is 64Tass, which can be found here: https://sourceforge.net/projects/tass64 ... =directory
64Tass outputs for the following: 6502/65C02/R65C02/W65C02/65CE02/65816/DTV/65EL02. 64Tass is multi-platform and runs from the command line. I use it right in Notepad++ and it has great macro capabilities, an extensive help file in PDF format, great source listings, a super-clean syntax (the one thing I find to be the best feature of all), and the ability to output segmented code, which is very useful for ROMs, carts, etc. In addition, 64Tass is in active development and new features are added all the time -- it is very stable.
In terms of 65816 programming 64Tass is excellent. I have used it for several years to program complex, multi-kernal ROMs for the SuperCPU, drive code, and OS extensions (sometimes all in the same batch); to date I have not experienced a single "bug" not related to my own coding errors :oops:
Open source, lightweight, and ultra-fast at only 400K or so -- your 1 MB source script with 100+ files will complete in just a second or two -- it's so good that I have been mulling converting it to x86 (and '816) assembly language as sort of a future side project. The author is a great guy and I always admire how he readily responds to user's questions.
It cannot be overstated just how easy and effective 64Tass is to use.
PostPosted: Sun Dec 14, 2014 5:16 am
My in-house assembler Finitron 65002 assembler supports the 6502/65C02 and 65C816 as well. It supports macros (but alas not structured code) and runs as a console app in a command prompt in 64 bit windows.
It was most recently compiled with Dev-C++ / Gcc++.
I've found it to be a little buggy, but useful.
It can generate binary output, but also Verilog code output for initializing block-rams.
http://www.finitron.ca
PostPosted: Sun Dec 14, 2014 5:45 am
I continue to develop in Mike Kowalski's assembler/simulator, which I do know works on Win7 64 bit.
PostPosted: Sun Dec 14, 2014 2:20 pm
@satpro, thanks for the pointer to 64tass. I'll give that a try to see if I can stop using the dosbox program to run the legacy Tass.
PostPosted: Sun Dec 14, 2014 4:41 pm
You're welcome Martin. Soci has included some syntax highlighting files in one of the distro folders. 64Tass now works great with full highlighting in Relaunch64 as Soci also contributes to that cause. If you really want a nice environment Notepad++ (also available as a portable app) is hard to beat. It has an extremely robust editing feature set along with tons of plugins to extend it.
Let me know if you need any help getting 64Tass up and running.
PostPosted: Mon Dec 15, 2014 3:56 am
Rob, as long as it has macro capability, I'm sure there's a way to do the structured programming with it. I describe how in my feature on structure macros, at http://wilsonminesco.com/StructureMacros/index.html . There are links to the source code for doing it on the C32 assembler I use which definitely did not have support for structured code built in. It should not take much to adapt it. On another note, what happened to your BC CPU Yahoo group forum on microprocessor design? I was unable to post on Yahoo for several years, and apparently many others had the same problem, making the groups I was in seem to die, although not from lack of interest. Nothing has been posted there in over eight years. You are covering your RTF650002 here now though of course. Do you still have any interest in the BC CPU group?
satpro, thanks for the recommendation on the assembler. I added it to the assemblers section under software on my links page.
PostPosted: Mon Dec 15, 2014 7:09 pm
The Ophis assembler (https://github.com/michaelcmartin/Ophis) is pure Python, so it should run on anything. Note the syntax is a bit unusual.
PostPosted: Thu Dec 18, 2014 8:45 pm
You're welcome, Garth. A new version (1.51 r883) was just released on the 14th. A quick look through the source implies Soci added Apple output, which was not in previous versions. Not verified yet though.
https://sourceforge.net/projects/tass64/files/latest/download?source=typ_redirect
Users browsing this forum: Google [Bot] and 8 guests
