Even a relatively simple assembler should be able to equate a label with a register name, but it would still be a bit confusing in a large or complex program, because there would be an almost certain need for overlapping labels.
Here is a short SWEET-16 example, using
San Bergmans' assembler. Note the register equates starting around line #40:
0000- 5 ;-----------------------------------------------------;
0000- 6 ; BEER SONG FOR THE SWEET16 PSEUDO-PROCESSOR ;
0000- 7 ; BY BARRYM 2011-05-21 ;
0000- 8 ;-----------------------------------------------------;
0000- 9 ; THANKS TO SBPROJECTS.COM FOR LOTS OF VALUABLE INFO ;
0000- 10 ; AND A VERY NICE ASSEMBLER!! ;
0000- 11 ; THE SWEET16 PROCESSOR WAS CREATED BY STEVE WOZNIAK ;
0000- 12 ; IN 1977 TO HELP HIM WRITE COMPACT (BUT SLOWER) ;
0000- 13 ; 16-BIT CODE ON HIS NEW BABY, THE APPLE II. HE ;
0000- 14 ; NEVER BUILT IT IN HARDWARE, BUT INSTEAD CREATED ;
0000- 15 ; A NIFTY LITTLE 372-BYTE INTERPRETER AND BURNED ;
0000- 16 ; IT INTO THE ROM OF THE ORIGINAL INTEGER BASIC ;
0000- 17 ; APPLE II. ;
0000- 18 ; SWEET16 CODE AND 6502 CODE CAN CO-EXIST PEACEFULLY ;
0000- 19 ; IN AN APPLE II MACHINE LANGUAGE PROGRAM; A 6502 ;
0000- 20 ; 'JSR $F689' IMMEDIATELY PRECEDES A BLOCK OF IN- ;
0000- 21 ; LINE SWEET16 INSTRUCTIONS AND A SWEET16 'RTN' ;
0000- 22 ; SWITCHES BACK TO 6502 MODE, WHICH MUST BE DONE ;
0000- 23 ; AT OR BEFORE PROGRAM COMPLETION. THE ORIGINAL ;
0000- 24 ; APPLE II HAD AN UPPER-CASE 40-COLUMN DISPLAY AS ;
0000- 25 ; STANDARD EQUIPMENT, SO THE OFFICIAL SONG LYRICS ;
0000- 26 ; ARE ADJUSTED ACCORDINGLY. ;
0000- 27 ; NOTE: 'ADD' AND 'SUB' ARE BUILT-IN 6502 MACROS IN ;
0000- 28 ; THE CURRENT VERSION OF THIS ASSEMBLER AND WILL ;
0000- 29 ; NOT ASSEMBLE TO THE CORRECT SWEET16 OPCODES (USE ;
0000- 30 ; '.DA #$AX' FOR 'ADD X' & '.DA #$BX' FOR 'SUB X') ;
0000- 31 ;-----------------------------------------------------;
0000- 32 ; CONSTANT EQUATES ;
0000- 33 ;-----------------------------------------------------;
F689- 34 SWEET16 = $F689 ROM: WOZ' INTERPRETER
E51B- 35 BIN2ASC = $E51B ROM: PRINT UNSIGNED16
FDED- 36 PUTCHAR = $FDED ROM: PRINT CHARACTER
0063- 37 MAXB = 99 MUST BE IN [1..65535]
0000- 38 ;-----------------------------------------------------;
0000- 39 ; REGISTER EQUATES ;
0000- 40 ;-----------------------------------------------------;
0000- 41 ACC = $0 SWEET16 MAIN ACCUMULATOR
0001- 42 BEER = $1 BEER COUNTER
0002- 43 TYPE = $2 SUBPHRASE TYPE TEMP
0003- 44 PTR = $3 TEXT POINTER
000C- 45 STK = $C SWEET16 STACK POINTER
0000- 46 ;-----------------------------------------------------;
0000- 47 ; MAIN PROGRAM ;
0000- 48 ;-----------------------------------------------------;
0E00- 49 .OR $0E00
0E00-20 89 F6 50 MAIN JSR SWEET16 ENTER SWEET16 MODE
0E03-1C 00 01 51 SET STK,$0100 INIT SWEET16 STACK POINTER
0E06-11 63 00 52 SET BEER,MAXB BEER = MAXB
0E09-B0 53 .DA #$B0 'SUB ACC' (TYPE=0)
0E0A-0C 07 54 BS PRSONG PRINT THE ENTIRE SONG
0E0C-00 55 RTN RETURN TO 6502 MODE
0E0D-60 56 RTS EXIT
0E0E- 57 ;-----------------------------------------------------;
0E0E- 58 ; PRINT ALL EXCEPT THE LAST SENTENCE ;
0E0E- 59 ;-----------------------------------------------------;
0E0E-13 5C 0E 60 BEERME SET PTR,TAKE EMIT "TAKE ONE ... IT AROUND,"
0E11-0C 12 61 BS PRBOB EMIT " ... ON THE WALL."
0E13-13 7D 0E 62 PRSONG SET PTR,CR EMIT BLANK LINE
0E16-0C 0D 63 BS PRBOB EMIT " ... ON THE WALL";
0E18-F0 64 DCR ACC TYPE = -1
0E19-13 7C 0E 65 SET PTR,COMCR EMIT ","
0E1C-0C 07 66 BS PRBOB EMIT " ... OF BEER."
0E1E-E0 67 INR ACC TYPE = +1
0E1F-F1 68 DCR BEER BEER = BEER - 1
0E20-09 EC 69 BNM1 BEERME IF BEER <> -1 THEN BEERME
0E22- 70 ;-----------------------------------------------------;
0E22- 71 ; SET UP LAST SENTENCE AND FALL THRU ;
0E22- 72 ;-----------------------------------------------------;
0E22-11 63 00 73 SET BEER,MAXB BEER = MAXB
0E25- 74 ; EMIT "GO TO ... BUY SOME MORE,"
0E25- 75 ;-----------------------------------------------------;
0E25- 76 ; PRINT A PROPERLY PUNCTUATED BOTTLE SUB-PHRASE ;
0E25- 77 ; (ENTRY): PTR CONTAINS PRE-STRING POINTER, ACC ;
0E25- 78 ; CONTAINS SUB-PHRASE TYPE (0 = " ... THE WALL", ;
0E25- 79 ; -1 = " ... OF BEER.", +1 = " ... THE WALL.") ;
0E25- 80 ; (EXIT): ACC IS CLEARED ;
0E25- 81 ;-----------------------------------------------------;
0E25-32 82 PRBOB ST TYPE
0E26-0C 25 83 BS PUTS EMIT PRE-STRING
0E28-21 84 LD BEER IF BEER = 0 THEN
0E29-06 0E 85 BZ PRBOTT EMIT "NO MORE";
0E2B-00 86 RTN IF BEER > 0 THEN
0E2C-A5 03 87 LDA $03 RETURN TO 6502 MODE JUST
0E2E-A6 02 88 LDX $02 LONG ENOUGH TO CONVERT AND
0E30-20 1B E5 89 JSR BIN2ASC EMIT BEER TO ACTIVE OUTPUT
0E33-20 8C F6 90 JSR SWEET16+3
0E36-13 86 0E 91 SET PTR,BOTTL
0E39-0C 12 92 PRBOTT BS PUTS EMIT " ... BOTTLE";
0E3B-F1 93 DCR BEER
0E3C-07 01 94 BNZ NEQ1 IF BEER = 1 THEN
0E3E-E3 95 INR PTR SKIP OVER THE "S"
0E3F-E1 96 NEQ1 INR BEER
0E40-0C 0B 97 BS PUTS EMIT " ... OF BEER";
0E42-22 98 LD TYPE
0E43-08 05 99 BM1 NOWALL IF TYPE >= 0 THEN
0E45-0C 06 100 BS PUTS EMIT " ON THE WALL";
0E47-22 101 LD TYPE
0E48-06 11 102 BZ KPUT IF TYPE <> 0 THEN
0E4A-13 A5 0E 103 NOWALL SET PTR,DOTCR EMIT "."
0E4D- 104 ;-----------------------------------------------------;
0E4D- 105 ; PRINT A NULL-TERMINATED STRING @ PTR ;
0E4D- 106 ; (ENTRY): PTR POINTS TO THE START OF THE STRING ;
0E4D- 107 ; (EXIT): PTR POINTS TO THE NEXT STRING IN MEMORY, ;
0E4D- 108 ; ACC IS CLEARED ;
0E4D- 109 ;-----------------------------------------------------;
0E4D-43 110 PUTS LD @PTR GRAB CHAR @ PTR AND ADVANCE PTR
0E4E-06 0B 111 BZ KPUT IF CHAR <> NULL THEN
0E50-00 112 RTN ESC TO 6502 MODE
0E51-A5 00 113 LDA $00 JUST LONG ENOUGH TO EMIT
0E53-20 ED FD 114 JSR PUTCHAR THE CHAR TO ACTIVE OUTPUT
0E56-20 8C F6 115 JSR SWEET16+3
0E59-01 F2 116 BR PUTS LOOP UNTIL NULL
0E5B-0B 117 KPUT RS RETURN
0E5C- 118 ;-----------------------------------------------------;
0E5C- 119 ; OPTIMIZED SONG LYRIC STRING ;
0E5C- 120 ;-----------------------------------------------------;
0E5C-D4 C1 CB C5
0E60-A0 CF CE C5
0E64-A0 C4 CF D7
0E68-CE A0 C1 CE
0E6C-C4 A0 D0 C1
0E70-D3 D3 A0 C9
0E74-D4 A0 C1 D2
0E78-CF D5 CE C4 121 TAKE .AS -"TAKE ONE DOWN AND PASS IT AROUND"
0E7C-AC 122 COMCR .AS -","
0E7D-8D 00 123 CR .AZ -#13
0E7F-CE CF A0 CD
0E83-CF D2 C5 124 .AS -"NO MORE"
0E86-A0 C2 CF D4
0E8A-D4 CC C5 00 125 BOTTL .AZ -" BOTTLE"
0E8E-D3 A0 CF C6
0E92-A0 C2 C5 C5
0E96-D2 00 126 .AZ -"S OF BEER"
0E98-A0 CF CE A0
0E9C-D4 C8 C5 A0
0EA0-D7 C1 CC CC
0EA4-00 127 .AZ -" ON THE WALL"
0EA5-AE 8D 00 128 DOTCR .AZ -".",#13
0EA8-C7 CF A0 D4
0EAC-CF A0 D4 C8
0EB0-C5 A0 D3 D4
0EB4-CF D2 C5 A0
0EB8-C1 CE C4 A0
0EBC-C2 D5 D9 A0
0EC0-D3 CF CD C5
0EC4-A0 CD CF D2
0EC8-C5 AC 8D 00 129 .AZ -"GO TO THE STORE AND BUY SOME MORE,",#13
0ECC- 130 .EN
Mike
