Welcome, mikaelmoizt!
Fewer operations, eh. Does it have to be economical with memory use? Lookup tables can cost a lot of memory -- it varies -- but it's a very powerful approach, and often the fastest (fewest operations). In this case the lookup just outputs a masked, shifted version of the input. But far more complex translations are possible. Basically you pre-compute whatever results you want and make a table to hold.them.
cheers,
; the code
LDX $input
LDA LookupTable,X
STA $firstbyte_output
TXA
AND #$0F
STA $secondbyte_output
;the lookup table
LookupTable:
DB $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00
DB $01, $01, $01, $01, $01, $01, $01, $01, $01, $01, $01, $01, $01, $01, $01, $01
DB $02, $02, $02, $02, $02, $02, $02, $02, $02, $02, $02, $02, $02, $02, $02, $02
DB $03, $03, $03, $03, $03, $03, $03, $03, $03, $03, $03, $03, $03, $03, $03, $03
DB $04, $04, $04, $04, $04, $04, $04, $04, $04, $04, $04, $04, $04, $04, $04, $04
DB $05, $05, $05, $05, $05, $05, $05, $05, $05, $05, $05, $05, $05, $05, $05, $05
DB $06, $06, $06, $06, $06, $06, $06, $06, $06, $06, $06, $06, $06, $06, $06, $06
DB $07, $07, $07, $07, $07, $07, $07, $07, $07, $07, $07, $07, $07, $07, $07, $07
DB $08, $08, $08, $08, $08, $08, $08, $08, $08, $08, $08, $08, $08, $08, $08, $08
DB $09, $09, $09, $09, $09, $09, $09, $09, $09, $09, $09, $09, $09, $09, $09, $09
DB $0a, $0a, $0a, $0a, $0a, $0a, $0a, $0a, $0a, $0a, $0a, $0a, $0a, $0a, $0a, $0a
DB $0b, $0b, $0b, $0b, $0b, $0b, $0b, $0b, $0b, $0b, $0b, $0b, $0b, $0b, $0b, $0b
DB $0c, $0c, $0c, $0c, $0c, $0c, $0c, $0c, $0c, $0c, $0c, $0c, $0c, $0c, $0c, $0c
DB $0d, $0d, $0d, $0d, $0d, $0d, $0d, $0d, $0d, $0d, $0d, $0d, $0d, $0d, $0d, $0d
DB $0e, $0e, $0e, $0e, $0e, $0e, $0e, $0e, $0e, $0e, $0e, $0e, $0e, $0e, $0e, $0e
DB $0f, $0f, $0f, $0f, $0f, $0f, $0f, $0f, $0f, $0f, $0f, $0f, $0f, $0f, $0f, $0f
