It is currently Sun Nov 24, 2024 11:19 am
PostPosted: Wed Jul 30, 2014 11:29 am
I found a more recent version of Peter Jennings' Microchess:
http://benlo.com/files/Microchess6502.txt
with the comment
Updated with corrections to earlier OCR errors by Bill Forster, August 2005.
which I compared to our archived version at http://6502.org/source/games/uchess/uchess.htm
I found these differences:
JSR  GNM
instead of the commented out
;      JSR   OHM             ; CONTINUATION
CKMATE           LDX  BMAXC
instead of
CKMATE  LDY     BMAXC
beq  pout25
instead of
bne     pout25
and
cph      .byte        "KQRRBBNNPPPPPPPPKQRRBBNNPPPPPPPP"
instead of
cph             .byte   "KQCCBBRRPPPPPPPPKQCCBBRRPPPPPPPP"
There's also an ordering change which may or may not be significant:
PrintDig       AND   #$0F
               PHY
instead of
   PrintDig       PHY
                  AND   #$0F
I haven't tested or run either version.
(Possibly via Oscar's KIM-1 adventures)
PostPosted: Wed Jul 30, 2014 4:12 pm
The last 3 changes are in the modifications to drive a serial terminal. Therefore I don't think they are due to OCR decode errors.
beq  pout25
instead of
bne     pout25
reverses the way empty white or black space is displayed. White is now displayed as two asterisks while black is displayed as two blanks. Was originally reversed. What you need really depends on wether you have a black on white or white on black terminal.
instead of
seemed to show rook=C & knight=R, maybe for another language. Now it is rook=R, bishop=B & knight=N.
And of course the last change is not significant, as Ed already said. However, I have replaced the hex nibble output in my code anyway. Was:
PrintDig       AND   #$0F              ;  prints A hex nibble (low 4 bits)
               PHY
               TAY                     ;
               LDA   Hexdigdata,Y      ;
               PLY
               jmp   syschout          ;
Hexdigdata   asc   "0123456789ABCDEF"
Gets rid of the table:
               CMP   #$0A              ; >9 ?
               BCC   PrDA              ; No
               ADC   #$06              ; A-F
PrDA           ADC   #$30              ; +"0"
               jmp   syschout          ;
The other fixes may be significant for the strategic behavior of the program as JSR GNM calls "generate move" for strategic analysis and loading BMAXC (black max count) to the wrong register may not be able to detect a potential checkmate against black properly.
PostPosted: Wed Jul 30, 2014 4:23 pm
Thanks for the analysis! It's good to do without the C02 opcodes too.
