Hi
Can anyone help me with this schematic? It's for the Control Universal EuroBeeb card. The serial port has a 5v driver circuit (so I'm told) but I am not sure how to connect it. I will be linking it to a BBC Micro (RS-423, 6v level serial) but I am not sure how to read the schematic. It says there are two RXD and two TXD lines, and they are connected to a circuit I don't recognise, but look like op amps. There are + and - connections.
On the BBC end, I only have 0v and TXD / RXD / CTS / CTS. Would it be safe to plug the ov into the -ve side of the EuroBeeb's TX / RX lines, and BBC TXD/RXD tp the +ve side of the corresponding lines on the EuroBeeb?
I'm going off this
http://mdfs.net/Info/Comp/BBC/CUBE/cube65.png - the serial connector is on the left hand side above the IC list (table).
Failing that, I suppose I should be connecting a proper RS-232 line driver (MAX232 - on order) to the ACIA, but I want to try and connect it to the BBC Micro first.
Thanks
JonB
