I've just finished building an EhBASIC ROM for my homebrew 6502 CPU card/backplane/UART system. RAM is 32Kbytes starting at $0000, ROM is 16Kbytes (27128) starting at $C000 with I/O in between.
The problem is, although EhBASIC will (sometimes) boot to the point of giving me the "Memory size?" signon message, it never manages to run actual code - if, for example I type in the following program:
10 FOR I=1 TO 5
20 PRINT I
30 NEXT I
RUN
Can anyone shed some light on this problem? Bad RAM logic?
My monitor ROM is based on the one on the ehbasic website, except I've rewritten the UART access routines (I'm using a 16C550, not a 6551).
Thanks.
