It is currently Sun Nov 24, 2024 3:48 am
PostPosted: Mon Jun 09, 2014 2:16 pm
Might be of historical interest, might actually cover some details of the 65816 in a different way from the usual datasheet from WDC. This implementation can only be clock-stopped with the clock high, it seems. And it only goes up to 8MHz.
Pages 257-280 of http://bitsavers.trailing-edge.com/pdf/ ... I_ASIC.pdf
(26 Mbyte file)
Extra points if you find any unambiguous differences compared to the WDC product!
PostPosted: Mon Jun 09, 2014 4:28 pm
... Extra points if you find any unambiguous differences compared to the WDC product!
I sense a sly grin here ... you already found something, didn't you?
Coverage starts on page 257.
Mike
PostPosted: Mon Jun 09, 2014 4:38 pm
No, I didn't compare as such, but I thought it suspicious on page 263 it says that a page-crossing branch has no penalty in native mode. On reflection, maybe that's expected - 16bit arithmetic in a single cycle.
I see there's a cycle-by-cycle tabulation on 267 - I don't think we had one for the '816 before. It shows for example that JSR performs the stack pushes in different cycles than does the '02.
PostPosted: Mon Jun 09, 2014 4:56 pm
There is no page-crossing penalty in native mode, so page 263 is correct. If in emulation mode, the page-crossing penalty does apply.
PostPosted: Wed Jun 11, 2014 6:22 am
The WDC '816 datasheet has one, namely Table 5-7. But, as you say, it's good to have a "second opinion," especially since WDC doc is so typo-prone. Good score! Thanks for posting.
PostPosted: Wed Jun 11, 2014 7:18 am
Oops - you can tell I didn't have the energy to revisit WDC's datasheet!
PostPosted: Wed Jun 11, 2014 3:43 pm
At 62 pages long the data sheet for the w65c265 is like a novella. It took me several sitting to get through it:
http://www.mouser.com/ds/2/436/w65c265s-2125.pdf
PostPosted: Wed Jun 11, 2014 5:46 pm
It's too bad that WDC's µcontrollers have mask-programmed ROM. It would have been better to have more on-board RAM with a simple means of attaching an external ROM. Otherwise, it's tempting to have all that hardware in a single device.
PostPosted: Wed Jun 11, 2014 7:43 pm
I agree more internal RAM would be handy, even with the masked ROM. There's a bit in one of the control registers that disables the internal ROM, so that's fixable. On the WDC web site they have the spec for a developer board which would make a nice starting point for an SBC project using this MCU:
http://www.westerndesigncenter.com/wdc/ ... 65c265.cfm
Users browsing this forum: No registered users and 67 guests
cron
