Klaus2m5 wrote:
If it is for slave selects of an SPI interface there is another option. Have you ever looked at a 3 to 8 decoder chip?
The 74HC137 seems to be ideal as it has a latch with low strobe (GL) and decodes 3 bits into 8 with enable. So you could have $x0-$x7 selecting the slave and any of $x8-$xF disabling the slave select (A-C=A0-2, G2=A3, G1=1).
I'm familiar with the '138/'238 and '139 but I've never looked at the '137. Thank you. I'll grab the Datasheet.
However, as with the 573 data must be valid for the whole duration of chip select but CS is now active low. A chip select to write a latch is not required to be active for the whole duration of PH2, but for any time inside the period where data is valid. So a short strobe generated by the PIC will do.
This deserves a closer look. Thank you, Klaus.
