It is currently Sat Oct 05, 2024 10:46 pm
PostPosted: Tue Feb 18, 2014 8:38 pm
The popular Arduino boards run at something like 16MHz, and apparently have a standard interface for external SRAM. For $25 you can get a half-megabyte SRAM expansion card - it uses 12ns SRAM and cycle time seems to be 4 cycles. Or a smaller one for $20.
I thought it might be interesting to consider using this interface and form factor for 6502 or similar projects.
http://ruggedcircuits.com/html/megaram.html
http://ruggedcircuits.com/html/quadram.html
A DIY design including PCB design files and links to relevant datasheets:
http://andybrown.me.uk/wk/2011/08/28/51 ... ga-design/
A 12ns 512kbyte SRAM: http://uk.mouser.com/Search/Refine.aspx ... 096A-12JCN
Edit: I should add that the memory expansion bus only offers 16 address bits, so these are necessarily banked designs with 64k banks.
PostPosted: Wed Feb 19, 2014 8:28 am
(I should mention also Garth's memory module, based on eight 10ns Cypress CY7C1049D-10VXI 512Kx8 5V SRAMs and offering 4 Mbytes. See http://wilsonminesco.com/WM-1_4Mx8SRAMm ... -15-13.pdf)
PostPosted: Wed Feb 19, 2014 8:51 am
Yes, thankyou, and if you want to save money and don't need the whole 4 megabytes, they don't have to be fully populated-- although there would hardly be any point in using one with only one or two ICs on it. I have the sockets for them too, both soldertail and wire-wrap, although the wire-wrap ones are super expensive. They cost me $11 each! :shock:
Users browsing this forum: Google [Bot] and 40 guests
