It is currently Fri Nov 22, 2024 3:59 pm
PostPosted: Tue Jan 07, 2014 3:06 pm
Hi,
I'm working with the simulator of Michal Kowalski, the 6502 simulator.
My problem is the using of a macro.
I copy the code below, with this one i don't understand why the complier accept an address for the argument and not a constant value.
;Macro
SETB: .MACRO BITSET,DONNEE
LDA BITSET
TSB DONNEE
.ENDM
Call of the macro, Compile OK
SETB 1,Temp
Call of the macro, Compile NOK
SETB #$1,Temp
Error mount by the compiler:
ERROR E038: Not enough parameters in macro call. ROW 21
Thank you very much for your help.
PostPosted: Tue Jan 07, 2014 6:08 pm
Surely
BitSet .macro bit,addr
lda #1<<bit
tsb addr
.endm
Andrew Jacobs
PostPosted: Tue Jan 07, 2014 6:27 pm
At first I misunderstood what you're trying to do. I think maybe Andrew did, too.
Is that really what you meant? In the first example you want to fetch from memory location 1 and use that as your bitmask?
cheers (and welcome!),
PostPosted: Tue Jan 07, 2014 6:34 pm
khittouchh wrote:
Hi,
;Macro
                      LDA     BITSET
                      TSB     DONNEE
          .ENDM
SETB 1,Temp
SETB #$1,Temp
Firs things first (pardon my pedantry). You are using an assembler, not a compiler. One *assembles* assembly language, not compiles. :)
Addressing your problem, macro parameters can only be literal numeric values (binary, decimal or hexadecimal), labels and symbols. Tokens such as # are not accepted in the parameter list. Hence your first example will assemble without error, but the second example will not.
The code within the macro definition dictates how the assembler will parse the parameters. As both instructions in your macro definition are not written to use immediate addressing, the expansion of the macro will always produce instructions using absolute or zero page addressing.
Another way to write this macro would be:
SETB     .MACRO  .B,.D
         LDA .B
         TSB .D
         .ENDM
Several things worth noting:
  1. The macro name SETB does not need a colon. That is, SETB: is not necessary. The Kowalski assembler always assumes that a field starting in the first column is a label, macro name or symbol. I recommend you do not use a colon in any label name.
  2. I changed the dummy operand names in the macro definition to single letters preceded with periods. Therefore, these names will not be known outside of the macro itself and thus may be reused elsewhere in your source code. Any label or symbol preceded with a period is a local definition and thus has a scope that is bounded by the nearest non-local definitions. Keep in mind that when the macro is invoked in your code the dummy operands take on the values of the parameters passed in the macro invocation. If you use global names for the dummy operands they become known outside of the macro. You will encounter an assembly error in such a case on the next invocation, as you will be trying to redefine an already defined symbol.
If you want to be able to cause conditional assembly, that is, be able to have parameters assembled as immediate or non-immediate operands, you will need to use extra parameters in the macro to tell it how to evaluate the dummy operands at assembly time. Use of various assembler pseudo-ops will be required to write the necessary logic. See the following:
;KOWALSKI SIMULATOR ASSEMBLER DIRECTIVES — BigDumbDinosaur (revised 2012/07/01)
 IO_AREA           ;define console I/O area address (no leading dot in IO_AREA)
 .ASCII .BYTE .DB  ;generate static data, such as strings, tables, etc.
 .ASCIS            ;generate character string w/bit 7 of last byte set
 .DBYTE .DD        ;assemble big-endian word
 .DCB              ;equivalent to * = * + N, where N is arg to .DCB,...
                   ;w/optional initialization pattern, e.g., .DCB 10,$FF, which will
                   ;reserve 10 bytes & fill them with $FF
 .DS .RS           ;equivalent to * = * + N, where N is arg to .DS or .RS
 .DW .WORD         ;assemble little-endian word
 .ELSE             ;conditional assembly directive
 .END              ;mark end of source file, optional
 .ENDIF            ;mark end of conditional assembly
 .ENDM             ;mark end of macro definition
 .ENDR             ;mark end of repeated text
 .ERROR            ;emit an error message & halt assembly, e.g., .ERROR "!!! operand out of range !!!"
 .EXITM            ;halt macro expansion
 .IF               ;start conditional assembly
 .INCLUDE          ;insert contents of named source file, e.g., .INCLUDE "include\atomic.65s"
 .IO_WND           ;define console I/O window size (cols, rows)
 .MACRO            ;mark start of macro definition, w/optional comma-separated parameters
 .OPT              ;set global assembly options
 .ORG              ;set start of assembly address, same as * = <addr>
 .PARAMTYPE        ;determine macro parameter type: 1 = numeric, 2 = string,...
                   ;.IF .PARAMTYPE(.op) == 1
 .REF              ;determine if label/symbol was defined,...
                   ;e.g., .IF .REF(ABC) evaluates true if ABC has been defined; logic can be reversed with !.REF (ABC)
 .REPEAT .REPT     ;repeat following text, e.g., .REPT 5
 .ROM_AREA         ;set simulator's write-protected address range
 .SET              ;(re)define variable value, e.g., X .SET 1 allows X to be redefined by a later .SET.  .= is a synonym for .SET
 .START            ;set simulator start of execution address
 .STR .STRING      ;generate text string, 1st byte is length, 255 bytes maximum
 .STRLEN           ;determine macro parameter string length
.IF evaluations can use the following binary operators:
    ==  "is equal to"
    !=  "is not equal to"
    >   "is greater than"
    <   "is less than"
.IF .X means "if .X is non-zero".
Pseudo-ops are not case-sensitive.
PostPosted: Tue Jan 07, 2014 8:23 pm
Writing macros that rely on text substitution to supply the addressing mode as a parameter is bad practice in my book. You should have two macros, for example
BitSetImm .macro value,addr
 lda #value,
 tsb addr
 .endm
BitSetVar .macro var,addr
 lda var
 tsb addr
 .endm
Given the simplicity of the instructions in this case and the variability the original poster was after I don't think macros are appropriate at all.
I think the same criteria should be applied as are with inline functions in C, that is, there should either be a clear saving in time (e.g. programmers or execution) or space (memory or source code). For eample
A simple macro that changes the MX bits on a 65816 and configures the assembler is OK because it saves me looking it up every time I need to do it (e.g. makes code better and more consistent by encapsulating knowledge that is needed repeatedly).
A simple macro that deposits the code to do something in less cycles that it takes to put data into standard variables, call a subroutine and put the results back where they are needed by generating code that processes the data directly is OK (e.g. custom code generation for maths operations).
A macro that generates custom code for complex operations that might otherwise be represented by duplicated chunks of source code with trivial differences in the same or different projects (i.e. code to initialize an LCD module, task switching, utilities).
Andrew Jacobs
PostPosted: Tue Jan 07, 2014 8:25 pm
To say the same thing another way, the "#" is the addressing mode, not the parameter. If you want to be able to use the macro with different addressing modes and methods of specifying the mask, for example bit number (like BitWise showed) versus an immediate mask versus fetching a mask from a memory location, you could use conditional assembly inside the macro, and use an additional parameter to tell which way you want it.
I'm not familiar with Kowalski's assembler and simulator but I do like to always use a colon after a label, so if I do a search for it, it goes right to it, rather than first turning up a lot of references to the label instead of the label itself. In the case of a macro, it always has to be defined before it's used anyway, but there could be references to it in the preceding comments.
PostPosted: Wed Jan 08, 2014 2:59 am
What I do is something like the following:
;scsicmd: EXECUTE SCSI COMMAND
;   Preparatory Ops : .A:  8 bits: target device SCSI ID
;                     .X: 16 bits: command descriptor block address
;                     .Y: 16 bits: buffer address (1)
...more comments follow...
scsicmd  rep @11111111         ;clear all SR flags
I'm so accustomed to the official MOS Technology reference assembler syntax, which did not accept a colon with a symbol or label, that I studiously avoid that syntax. So I use the colon where it naturally fits: in the subroutine's comment header.
PostPosted: Wed Jan 08, 2014 5:29 am
A little off-topic, and I'm anxious to hear if khittouchh got things figured out; but regarding labels, there are places where they come fast and furious and there aren't normally a lot of comments with them, like in this portion from my '816 Forth source in the normal math operations section where they're run-of-the-mill Forth words, well documented elsewhere:
 ; The next few words starting with U go faster than their non-U counterparts
 ; by avoiding M/MOD above.  Use them to speed up execution when you're using
 ; unsigned numbers or when you know the inputs will never be negative.
        HEADER "U/MOD", NOT_IMMEDIATE   ; ( u1 u2 -- rem quot )
UsMOD:  DWL     nest, ZERO, SWAP, UMsMOD, unnest
        HEADER "/", NOT_IMMEDIATE       ; ( n1 n2 -- quot )
SLASH:  DWL     nest, sMOD, NIP, unnest
        HEADER "U/", NOT_IMMEDIATE      ; ( u1 u2 -- quot )
Uslash: DWL     nest, UsMOD, NIP, unnest
        HEADER "MOD", NOT_IMMEDIATE     ; ( n1 n2 -- rem )
MOD:    DWL     nest, sMOD, DROP, unnest
        HEADER "UMOD", NOT_IMMEDIATE    ; ( u1 u2 -- rem )
UMOD:   DWL     nest, UsMOD, DROP, unnest
        HEADER "*/MOD", NOT_IMMEDIATE   ; ( n1 n2 n3 -- rem quot )
ssMOD:  DWL     nest, TO_R, Mstar, R_FR, MsMOD, unnest
        HEADER "U*/MOD", NOT_IMMEDIATE  ; ( u1 u2 u3 -- rem quot )
UssMOD: DWL     nest, TO_R, UMstar, R_FR, UMsMOD, unnest
        HEADER "*/", NOT_IMMEDIATE      ; ( n1 n2 n3 -- n1*n2/n3 )
STARSLASH: DWL  nest, ssMOD, NIP, unnest
        HEADER "U*/", NOT_IMMEDIATE     ; ( u1 u2 u3 -- u1*u2/u3 )
USTARSLASH: DWL nest, UssMOD, NIP, unnest
PostPosted: Wed Jan 08, 2014 8:50 pm
I'd also like to point out that not all macro assemblers have this limitation. I've certainly used this pattern in ca65, where each macro parameter effectively behaves a string substitution for these purposes.
PostPosted: Thu Jan 09, 2014 10:10 am
Hi,
you're right BigDumbDinosaur this is an assemblage and not a compilation.
I try to rewrite my macro but there is always an error.
SETB: .MACRO .B,.D
LDA .B
TSB .D
.ENDM
Use:
SETB #bit0,Temp (with bit0= $01 (constant))
Error : ERROR E038: Not enough parameters in macro call.
I want do to that because i inherit a lot of macro and i want to use it with the 6502 simulator.
Thanks you very much for yours answers.
Great forum.
PostPosted: Thu Jan 09, 2014 4:18 pm
As it has been said before, the Kowalski assembler does not support passing the immediate modifier to a macro. So you must define a macro like this:
        .ORG 0
bit0    .SET 1
Temp    .DS 1
SETBi   .MACRO .B,.D
    LDA #.B
    TSB .D
        .ENDM
    SETBi bit0,Temp
The immediate modifier is part of the opcode mnemonic and like the opcode itself cannot be passed as a parameter. Parameters may only be string or value.
PostPosted: Thu Jan 09, 2014 6:30 pm
It would be nice to be able to write something like that, but no such luck. In macros where I need the ability to assemble something as immediate or absolute/zero page addressing I use a flag parameter to tell the assembler what to do.
PostPosted: Fri Jan 10, 2014 8:52 am
HI,
Ok thank you very much for theses informations
Users browsing this forum: Miles J., nollkolltroll and 14 guests
