Europe's no-lead requirement has been bad too, as the no-lead solders are not as reliable...
In non-electrical usage, unleaded solders have proved problematic as well.
A friend who is a retired licensed plumber, and certified high pressure steam pipe fitter, mentioned some time back that the incidence of failed joints in copper potable water piping has significantly increased since the switch to lead-free solders. He also insists that the switch was pointless, as there is no scientific proof that the lead in the soldered joints was leaching into the water (I tried to find something to refute that and wasn't successful).
I'm well aware of the structural problems with no-lead soft solder, as I used type K copper pipe for the suction and return lines in my large-scale locomotive. I could not get joints soldered with the no-lead solder to hold up. The combination of expansion and contraction as the propulsion system heats up and cools down, along with the ever-present vibration when the unit is running, conspires to cause tiny cracks in the solder, and of course, leaks. I repaired joints several times, only to have them leak again. I finally redid all of the copper plumbing with 30/70 leaded acid-core solder (sold through industrial supply houses in the USA), which appears to have permanently solved the problem.
