It is currently Fri Nov 22, 2024 11:56 pm
PostPosted: Sun Nov 17, 2013 1:38 am
I think somewhere here on the forum once asked whether I was planning branches based on signed comparisons.
After looking at the v-flag primer, I am not sure they make sense: http://www.6502.org/tutorials/vflag.html
The problem I see is that only ADC and SBC modify the V-flag, but NOT the CMP operation!
And as far as I understand the signed number arithmethic, a branch greater or smaller on signed values depends on V.
Basically a set V-flag says, that the operation went out of the 8-bit space. So in principal, you should always use that to
handle error conditions - before actually using C/E for the unsigned greater/smaller branches.
So would a branch on a signed comparison even work?
And if I can't compare two numbers to get a signed comparison result (because CMP does not set V), the value of, say "BGTS" (branch greater than, signed)
would be rather small.
What do you think?
TIA
Andre
PostPosted: Sun Nov 17, 2013 7:09 am
How about modifying the CMP operation so that it sets V ? Seems sensible anyway.
PostPosted: Sun Nov 17, 2013 7:13 am
As CMP is really a subtraction that discards the difference, you'd think that V would be appropriately conditioned. It could be a very useful features.
PostPosted: Sun Nov 17, 2013 8:14 am
Another approach might be to have CMP set N and C according to the result of comparison rather than a subtract.
If signed(a) < signed(b) then set N.
If unsigned(a) < unsigned(b) then set C.
If a==b then set Z
http://www.finitron.ca
PostPosted: Sun Nov 17, 2013 10:17 am
I never understood, why the 6502 does not set V on a compare and why there is no compare with carry (borrow). Of course you must use SBC for signed compares! (N xor V) = signed less than if 1, = signed greater or equal if 0
PostPosted: Sun Nov 17, 2013 10:54 am
The problem with modifying CMP is of course compatibility.
I indeed wonder, why, if CMP does a substract internally, the V-flag is not set.
Maybe they only had an unsigned comparison in mind.
Yet, this N xor V makes coding it separately a pain, so maybe a branch on signed
still can make sense, the question is, is it worth the effort?
PostPosted: Sun Nov 17, 2013 10:59 am
If you don't want to break existing code, you could add an extra 'signed-less-than' flag that gets set by add/subtract/compare, and some extra branch instructions to check for it.
PostPosted: Sun Nov 17, 2013 12:31 pm
Yes, many other processors have it. After all it would be more usefull than many of the extra opcodes in the 65C02.
P.S.: Talking about the pain to do a 16-bit signed compare in the 6502: http://www.6502.org/tutorials/compare_beyond.html#6
Actually not that bad. :shock:
