It is currently Sun Sep 29, 2024 7:33 am
Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Wed Nov 13, 2013 10:36 pm
I suspect there may be some systems where the ISR keeps feeding data to the UART transmitter and the RTS line only gets looked at by a non-ISR task, leading to its taking more bytes to stop the flow than the UART's buffer has. IOW, that even if the UART had an 8-byte buffer, it may take more than 8 bytes to come to a stop. Is anyone aware of such a system?
PostPosted: Thu Nov 14, 2013 6:12 am
I'm not. The two UARTs with which I am familiar that have internal transmit FIFOs will indicate via a status register bit when the FIFO is full. In the case of the 26C92, it may be programmed so that it stops transmitting as soon as the receiving entity deasserts CTS, which is how I am using it in POC V1.1. The response time to CTS is sub-microsecond, which means transmission will be stopped well before the next start bit would be sent.
The buffer to which I am referring is the circular one maintained by the drivers in RAM.
PostPosted: Sat Nov 16, 2013 12:27 am
A quick update. I just started a new job this week so not as much time to play with this stuff now. I don't think I ever actually hit at flow control condition, probably since I need to send data quite slowly to give BASIC time to parse each line. I did find a bug in my code if I ever did hit that condition where it would try sending then get stuck in a loop waiting for the register to clear when it never would. I've also disabled interrupts around anything that is reading or writing the 6551 registers. If I don't try to hammer it with data it works quite well now. I had it successfully running overnight loading thousands of times error free.
So, that's working pretty well so I went and did another Usborne book review using it which is the whole reason for the machine: http://www.asciimation.co.nz/bb/2013/11/12/usborne-guide-to-understanding-the-micro
Have lots more to review (I have all of them but three).
I just added a CLS command to my version of Basic. And I also got hold of an old fashioned tape recorder. I'd quite like to make a real tape interface for it (maybe using an Arduino). More just as a novelty. For actual saving and loading I will probably write a little app that runs on the PC to send things via the serial port. I need to brush up on my Windows coding for my new job so that would be a good project too.
Simon
My 6502 related blog: http://www.asciimation.co.nz/bb/category/6502-computer
