It is currently Sat Nov 23, 2024 11:42 pm
 Post subject: W65C02S BE signal
PostPosted: Mon Oct 21, 2013 10:14 pm
Hi There!
Been ages since I've been here! I'm considering changing my board over from a z80 to a W65c02. It's a custom board coupled with an FPGA that uses DMA. On the Z80, it's pretty straightforward using /busreq and getting a /busack back. Anyone know how the W65c02(s) let's you know when the bus has tristated? The datasheet is a little sparse..
 Post subject: Re: W65C02S BE signal
PostPosted: Tue Oct 22, 2013 12:40 am
To quote the W65C02S data sheet:
    3.2 Bus Enable (BE)
    The Bus Enable (BE) input signal provides external control of the Address, Data and the RWB buffers. When Bus Enable is high, the Address, Data and RWB buffers are active. When BE is low, these buffers are set to the high impedance status. Bus Enable is an asynchronous signal.
Note the last sentence. If you want to get the 65C02 to relinquish control of the buses so you can do DMA, start a second MPU, etc., first halt it by asserting RDY whenever convenient, then assert BE to tri-state the buses. To restart the 65C02, deassert BE and then deassert RDY. The 'C02 will start on the next Ø2 high. You don't need a /BUSACK signal like with the Z80, since the 'C02 will do what it's told, when it's told.
Also note:
    3.5 Memory Lock (MLB)
    The Memory Lock (MLB) output may be used to ensure the integrity of Read-Modify-Write instructions in a multiprocessor system. Memory Lock indicates the need to defer arbitration of the bus cycle when MLB is low. Memory Lock is low during the last three cycles of ASL, DEC, INC, LSR, ROL, ROR, TRB, and TSB memory referencing instructions.
Incidentally, for your application, you probably should wait until SYNC goes high before asserting RDY and BE. Doing so will stop the 'C02 on the opcode fetch cycle, which should eliminate the need to monitor MLB, as the 'C02 will halt before it gets to the W part of R-M-W instructions. The same thing can be accomplished with the 65C816 by asserting RDY and BE when the expression VDA && VPA is true.
PostPosted: Tue Oct 22, 2013 1:21 am
Welcome back from the dark side! :D
As noted by BDD, Bus Enable is an asynchronous signal. What this means is that, unlike the z80, the W65c02 has no bus arbitration circuitry on-chip. You supply the hardware that manages the handover of the bus -- and suspends the CPU, using RDY. (Coupla gates & flip-flops... it's not that difficult. I expect it'd be a piece of cake with an FPGA.)
To be clear, there's no need to let you know. You can be sure the bus is tristated simply by negating BE then waiting a few nanoseconds. (For the exact figure, check tBV in the timing diagram.)
Also note:
3.5 Memory Lock (MLB) [etc]
Needless detail, IMO. The vast majority of DMA applications (eg: straight-forward Input/Output from an ordinary peripheral device) can ignore MLB, and also SYNC/VPA/VDA. An exception would be if the other device sharing the bus were another processor, and the two processors required a system of shared semaphores in memory.
cheers
PostPosted: Tue Oct 22, 2013 5:43 am
Also note:
:D
PostPosted: Tue Oct 22, 2013 6:04 am
yzoer wrote:
Hi There!
Sounds interesting. In fact, I was thinking about doing something similar. Do you have your Z80 project described somewhere ?
PostPosted: Tue Oct 22, 2013 6:07 am
But unless you're doing multiprocessor design (or something with the same effect) there's no need to treat RMW instructions in a special way.
PostPosted: Tue Oct 22, 2013 5:11 pm
Thanks for all the replies guys. I'd completely forgotten about the RDY line! Makes total sense now and should be pretty straightforward to implement.
Main reason for me 'defecting' to the dark-side was that I got introduced to the z80 when I was doing gameboy work. Heck, that wasn't even a full z80 so it's kinda like being introduced to the dark side by Jar Jar Binks. Grew up on 6502 on the vic/c64.
Anyway, I really have no excuse really. Number of reasons I'm coming back is that it's a) cheaper, b) faster at the same clock rate and c) it can run at 3.3v! There's no 3.3v z80 equivalent and while it's possible to use level-shifters and what not, I'd rather not. A 20mhz z80 costs you $10 whereas a 14mhz 65c02 will run you $3 cheaper.
As far as my hardware design goes, I haven't put it up yet but will (hopefully) soon. First PCB batch had some design errors and while those weren't major, I'd like to re-design it and add a couple of new features. Like changing it over to a 6502 :-)
-Yvo
Users browsing this forum: No registered users and 83 guests
cron
