It is currently Fri Nov 01, 2024 5:28 am
PostPosted: Fri Oct 11, 2013 12:22 pm
That was for my processor by the way. I had it set up with >64K of ram... in the simulator. But, it worked :P
PostPosted: Fri Oct 11, 2013 2:05 pm
I think the point that BDD was making is that # has a special meaning to the assembler. It means "treat the next expression as a literal". You wouldn't write "2 = 10" in C code. It doesn't make any sense. By omitting the #, you are telling the assembler that it is an address rather than a literal "memory[2] = 10".
That being said, assemblers aren't known for having the greatest error checking around, so it's entirely possible that one would accept that input and turn it into God knows what :-)
If you haven't done so already, you should download the Kowalski simulator and play around with some 6502 code to learn the finer points. Heck, you could even try out having your parser/lexer generate some object code for it (if you're in for a real adventure :-))
PostPosted: Fri Oct 11, 2013 5:36 pm
The final version of the Kowalski simulator, V1.2.12, was never made available for download, as Mike Kowalski is no longer maintaining the software. Attached is V1.2.12, which I have been using for more than a year.
File comment: Kowalski 65xx Simulator V1.2.12
6502_1.2.12.zip [527.02 KiB]
Downloaded 64 times
PostPosted: Fri Oct 11, 2013 7:18 pm
Do you think he would mind if it were made available for download in the http://6502.org/tools/asm/ section of 6502.org?
PostPosted: Fri Oct 11, 2013 8:18 pm
6502_1.2.12.zip
Hope wine can run this...
PostPosted: Fri Oct 11, 2013 8:27 pm
Yes, the last one I tried did run in WINE.
PostPosted: Fri Oct 11, 2013 9:42 pm
I doubt it. He sent me V1.2.12 after I discovered a bug in 1.2.11.
Users browsing this forum: Google [Bot] and 10 guests
