It is currently Fri Nov 15, 2024 8:47 pm
 Post subject: 6526 time of day clock
PostPosted: Sat May 15, 2004 5:37 am
In the time of day clock in the 6526 do the hours go from 0 to 11 or from 1 to 12 ?
00:00:00 to 11:59:59 or
01:00:00 to 12:59:59
Rob
PostPosted: Sat May 15, 2004 7:01 am
I found this data sheet for the chip.
http://www.surffi.net/~allu/shared/file ... ia6526.pdf
Andrew Jacobs
PostPosted: Sat May 15, 2004 2:29 pm
Rob
Rob,
As I recall, it will run from 01:00:00 to 12:59:59. However, the AM/PM flag is the high bit of the hour register. I don't recall all the specifics.
I did write TOD print and TOD set commands for my SBC-1. If you go to the Downloads section of my website and download the sbcmonitor.zip file, there is a file included called 6526.asm that contains the assembly code.
http://65c02.tripod.com/
Hope this helps.
Users browsing this forum: Google [Bot], John West and 7 guests
