r1 is synonymous for the 8-bit accumulator I suppose
I'm pretty sure PHA/PLA are working properly. All the memory loads go through a single state. Most of the stores (except jsr, ) go through a single store state.
I tried increasing the clock frequency to see if I could make the problem worse, but it didn't have an affect.
The V_OUTP routine calls DisplayChar which is outputting a character to a text display.
Hmm, I see now that I don't mask off the high order bits when DisplayChar is called. I suppose there could be garbage in the high order bits when switching from eight bit mode. I'll have to try masking off the high order bits.
