Yes...so, anyway, here's a little test program regarding unacceptable uses of ASSERT, not completely exhaustive:
; Hobby Cross-Assembler Error Test 008g
; Messages\Assert Messages
; error: failures detected on first pass (BDD1)
; by Anton Treuenfels
; first created: 08/28/13
; last revised: 08/28/13
; warning(s): 1
; error(s): 6
; fatal: 0
.listfile
.errfile
.cpu "T_16_L" ; required psop
.org $1000 ; required psop
assert ; try to make it a label
assert .bit16 $1000 ; try to make it a label
assert = $1000 ; try to assign a value
assert .macro ; try to make it a macro name
.endmacro ; (empty)
.macro assert ; try to make it a macro name
.endmacro
.end
and here's the error file created:
; >>>>> Error in TEST008G.A
; 0029: assert ; try to make it a label
; - Unexpected blank field
; 0031: assert .bit16 $1000 ; try to make it a label
; - Expecting operand: <.bit16 $1000>
; 0033: assert = $1000 ; try to assign a value
; - Expecting operand: <= $1000>
; 0035: assert .macro ; try to make it a macro name
; - Expecting operand: <.macro>
; 0036: .endmacro ; (empty)
; - Matching block structure not found
; 0038: .macro assert ; try to make it a macro name
; - Name already in use: <ASSERT>
; >>>>> Warning in TEST008G.A
; 0039: .endmacro
; - Definition ignored
1 Warnings detected
6 Errors detected
and I
used to think that was pretty good. But now I wondering if something like this might be even better:
; - While processing pseudo opcode: <ASSERT>
; - While processing pseudo opcode: <ENDMACRO>
; - While processing pseudo opcode: <MACRO>
; - Built-in symbol, pseudo opcode, mnemonic or function name: <ASSERT>
; 0039: .endmacro
1 Warnings detected
6 Errors detected
I don't think it would cost too much to add the 'while' line in terms of code or execution time, which would provide a clue as to what the assembler thinks is going on (processing pseudo op, instruction mnemonic, or user macro). And when a name conflict occurs it's certainly possible to distinguish between a built-in and a user-defined one.
This is what BDD has done to me
He's got me all worried about that poor programmer who can't for the life of him figure out why his
utterly reasonable code won't work.
