It is currently Fri Sep 27, 2024 3:25 pm
 Post subject: 6503 Application
PostPosted: Thu Apr 29, 2004 1:43 pm
Hello, I am familiar with the programming of the 6502; However, my latest project is reverse engineering a 6503 application. I have the pin out for the 6503 and thought the project was going to be easy, but.......
The application uses a Harris HM6543-5 Prom which only has a nibble (4 bits) of data which is tied into the lowest 4 bits of the 6502 data bus. The upper 4 bits are not connected to the 6543. They merely go to a PIA (along with the lower 4-bits) for I/O processing.
OK, my question. On power up, the hardware addressing is set to give FFFEh to enable the 6543; However, how can valid 4 bit commands be passed to the 6502 from the 6543? I am used to the 8-bit command set of the 6502.
:oops:
PostPosted: Thu Apr 29, 2004 3:10 pm
So there's not a second ROM to fill in the other 4 bits?
 Post subject: Only one
PostPosted: Thu Apr 29, 2004 3:30 pm
There is only one ROM IC! Strange huh?
Thanks for asking!
PostPosted: Thu Apr 29, 2004 4:20 pm
There's no sort of pulse input to get a lower and upper set of 4 bits? Unfortunately, I don't have a datasheet for that chip in front of me....
It sounds like it would be an addressing nightmare, as it would take 2 addresses to store one instruction.
-Tony
KG4WFX
Users browsing this forum: Google [Bot] and 15 guests
