It is currently Sun Oct 06, 2024 4:21 am
PostPosted: Fri Jun 07, 2013 11:50 am
Just found this page in the NESdev wiki: Assembly Optimisations
Contents:
    1 Optimise both speed and size of the code
    1.1 Avoid a jsr + rts chain
    1.2 Split word tables in high and low components
    1.3 Use Jump tables with RTS instruction instead of JMP indirect instruction
    1.4 Use a macro instead of a subroutine which is only called once
    1.5 Arithmetic shift right
    1.6 Easily test 2 upper bits of a variable
    1.7 Negating a value without temporaries
    1.8 Avoiding the need for CLC/SEC with ADC/SBC
    1.9 Test bits in decreasing order
    1.10 Test bits in increasing order
    1.11 Test bits without destroying the accumulator
    1.12 Use opposite rotate instead of a great number of shifts
    2 Optimise speed at the expense of size
    2.1 Use identity look-up table instead of temp variable
    2.2 Use look-up table to shift left 4 times
    3 Optimise code size at the expense of cycles
    3.1 Use the stack instead of a temp variable
    3.2 Use an "intelligent" argument system
(Via exploration of pages like this)
PostPosted: Fri Jun 07, 2013 7:16 pm
Thanks-- and that page has a link to a synthetic-instructions page which is also good.
PostPosted: Sun Aug 04, 2013 3:58 am
They don't seem to be giving Woz any credit for inventing the "RTS trick". Correct me if I'm wrong, but I believe that it was used publicly for the first time (at least on the 6502) in his SWEET-16 interpreter, circa 1977.
I love that guy! I have spent many hours studying (and trying to emulate) his spaghetti code style ... not very maintainable unless the source is well-commented, but delicious works of art nonetheless.
Mike
Users browsing this forum: Google [Bot] and 8 guests
