It is currently Sat Nov 23, 2024 11:42 pm
 Post subject: 14 Pin 74HC00 NAND
PostPosted: Fri Jul 26, 2013 11:01 pm
in the 6502 primer it mentioned address decoding pin A15 of the 6502 was connected to the NAND gate in a DIP-14 pack. what pin do I connect A15 to in a Philips NAND gate http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_906339_-1
JMP $FFD2
 Post subject: Re: 14 Pin 74HC00 NAND
PostPosted: Fri Jul 26, 2013 11:18 pm
There's almost no difference between the various manufacturers' gates with the same identifier (74HC00 in this case). They may brag about their part having better resistance to latch-up or something like that than the competitors' part, but for most purposes, they're equivalent.
But if you're wondering about the four sections, ie, the four NAND gates in the one package, they are all the same, so you just assign the different sections according to how it's easiest to layout a PC board or wire a prototyping board. It won't matter.
PostPosted: Fri Jul 26, 2013 11:23 pm
Sorry about a vague question what pin on the NAND gate do I connect a15 to and what pin outputs im talking about the address decoder you made to decode 32k rom and16k ram in the build your 6502 primer
JMP $FFD2
PostPosted: Fri Jul 26, 2013 11:30 pm
Ok, take section A of the quad NAND for example. It has two inputs, pins 1 and 2, and an output, pin 3. Pins 1 and 2 are interchangeable, so if you pick that section for that part of the circuit, it doesn't matter if A15 goes to 1 or 2. I don't know exactly which diagram you're looking at, but I suspect it's one where the other input pin goes to Vcc because we're only using that section as an inverter. 1 to A15 and 2 to Vcc, or vice-versa-- it doesn't matter.
Users browsing this forum: No registered users and 92 guests
cron
